View Full Version : bizhub 350 light copies
brent
05-26-2015, 10:32 PM
ok peeps I am drawing a blank light copies on a drum that had 50 percent left.. I did a drum unit. developer and developer unit. because it needed a dv it had like 400k and the problem persists. other then the laser unit. is there any advice on what I can check next. ? the copies are light but still readable. just am drawing a blank on this
and thought I would ask for help thanks
brent
blackcat4866
05-26-2015, 10:48 PM
Did you do any simulations, like a developer stir, or reset counts? =^..^=
brent
05-26-2015, 10:55 PM
Sure did. Reset counters. And ran an f8
blackcat4866
05-26-2015, 11:00 PM
Are you using OEM toner? =^..^=
fixthecopier
05-26-2015, 11:32 PM
Are the internal f-12 prints also light? are you running original through adf or on glass
allan
05-27-2015, 02:59 AM
Check the transfer. The contacts on the door bend.
And the developer gears break.
fixthecopier
05-27-2015, 11:03 AM
In addition to those door contacts, you indicated you changed the dv tank for being over 400k , if you have never changed the transfer roller, now is the time.
copier addict
05-27-2015, 02:18 PM
If you are using aftermarket toner, get rid of it. Since we switched back to OEM drums and toner we are getting up to and sometimes over 200% drum life. Service calls have gone way down and fusers are lasting quite a bit longer as well. The money we were saving on AM drums and toner was getting more than used up with service calls.
One of the main problems we had while using Densi toner on the BH350 series was low image density. It would be fine after a drum and dev change but get steadily lighter as the Densi toner got mixed in.
Just my two cents.
fixthecopier
06-03-2015, 11:49 AM
Ok Brent, how about a little closure on this.
wseyller
06-04-2015, 04:42 AM
Not sure if I missed it but I never saw mention if this happens with prints from computer or internal. I just saw copies being mentioned. Sure its not just dirty optics in scanner. Also there is user setting of adf for light/dark copies.
Edit: just noticed fixthecopier asked if F12 prints are light but never got an answer to that.
CraigW
06-04-2015, 02:59 PM
I had a 200 once that got light everything, and ended up being the drum unit in my case. Only about 40k into life also.
