View Full Version : BH 224e T-18 Fax error
splblazer91
06-01-2015, 03:32 AM
Anyone have a fix for this? I have already initialized the fax unit and still get the code randomly.
allan
06-01-2015, 06:27 AM
What is the specific error code you are getting?
Choclit007
06-01-2015, 06:45 PM
Code
Corrective Actions
T00
Check to see if the destination is correct.
Check the state of the recipient.
T05
T08
Check the line status.
T18
T28
T32
T42
T43
T48
Check that the fax number registered with the recipient is correct.
T58
The document to be sent by polling is not registered in the sender's machine. Ask the sender to set the document.
T60
Register the document that is sent to the recipient by polling.
T61
Check whether the document to be sent by polling from the bulletin board is registered.
T62
Inform the recipient of the correct bulletin board number.
T80
T81
T82
T85
T89
Check the balance in the billing management device.
T95
T97
Check the state of the fax board. (Contact your service representative. )
T98
Forwarding is not available for that combination. Check the forwarding settings.
T99
Check the destinations registered in the address book.
Code
Corrective Actions
R18
Check your machine. If toner or print paper is empty, supply them. If the memory is full, empty the memory.
R21
Turn the Closed Network RX function off, or inform the recipient of the correct password.
R22
R32
Change the setting for Auto Create User Box, or inform the recipient of the correct Confidential User Box number.
R50
R60
R63
R69
R72
Ask the sender to shorten the length of original to be sent before resending the fax.
R78
Turn the Main Power Switch off and back on.
R79
R93
After checking with the sender, register a Confidential User Box for confidential reception.
Check the password for the Confidential User Box.
R94
After checking with the recipient, register a Relay User Box for relay distribution.
Check the password for the Relay User Box.
R95
Check Forward TX Setting.
R96
Inform the recipient of the correct number for the Confidential User Box.
R97
Check PC-Fax RX Setting.
R99
splblazer91
06-02-2015, 02:13 AM
BH224E manual says check recipient, check paper tray or memory. Customer gets the error when faxing to several different numbers though.
EarthKmTech
06-02-2015, 12:55 PM
do you have any way of testing the transmission level over there ?
Here we can send a test fax to our local carrier and get a report back and adjust accordingly, when it actually works..
splblazer91
06-02-2015, 01:27 PM
Not that I know of. Phone companies here tend to be a pain to work with.
