eunos
06-01-2015, 11:57 AM
Hi all,
I'm using a batch print program (Print Conductor) to print bundles of documents.
Each document has a tabbed divider inserted before it as a front cover from the bypass tray.
When printing, there is a lag of anything between 1 to 5 minutes before the document prints, whilst the blue "receiving" light is flashing on the machine.
I really need to find a way of reducing this lag to speed up the prints. The documents being printed range from 250kb to 3mb.
If I can get the documents to spool up faster, then I will have found a quick and easy way to insert tabs into a print run, as the method of doing so through the driver is rather tedious and has a limit of 20 inserts.
I'm using Win 7, PS driver, and connected directly to machine via USB (and unplugged ethernet to stop others printing mid stack)
Many thanks,
Ben
Many thanks,
Ben
