View Full Version : BizHub Pro 1050 46-14 code
artfer
05-21-2008, 02:16 AM
Have worked on a BHP-1050 for several time and did not achieve resolve this malfunction.
When a misfeed or a paperjam occur, the machine makes a crazy free run for a while and then shows a 46-14 code.
I can't anderstand what is happenig.
any help will be accepted. Thanks in advance.
artfer
06-04-2008, 12:54 AM
Hi Guys,
the Problem was switch 12-02, it disables the jam detection.
thanks for all.
Hi,Can you tell me which is switch 12-02?You are talking about dpsw?Thanks in advance,Ilon
JustManuals
08-08-2012, 06:10 PM
http://www.justmanuals.com (http://www.justmanuals.com/)
Paul@justmanuals.com (Paul@justmanuals.com)
artfer
08-09-2012, 01:44 PM
Yes, but this information isn't on service manual. See attachment.
Thank you guys but SOLENOID MOUNTING PLATE was not in the right place, and all paper was going directly to the finisher, without writing the second side. after mounting SOLENOID MOUNTING PLATE in the right place everything was OK. Ilon
Paul Lau
08-24-2015, 05:25 PM
Thank you guys but SOLENOID MOUNTING PLATE was not in the right place, and all paper was going directly to the finisher, without writing the second side. after mounting SOLENOID MOUNTING PLATE in the right place everything was OK. IlonWhat is the location of the SOLENOID MOUNTING PLATE you are referring to
