Thanks Thanks:  0
Dislikes Dislikes:  0
Results 1 to 10 of 10
  1. #1
    Trusted Tech 50+ Posts Gina82's Avatar
    Join Date
    Oct 2017
    Location
    Greenwood, MS
    98
    Rep Power
    14
    Canon 2800 needs help
    I have a canon 2800 that gives a stationary jam after paper leaves fusing unit but before it reaches the delivery sensor. The paper stops in the middle of the vertical transport to the delivery section. I think it may be to M5 motor but when I go into service mode the motor always operates fine. If I go into the jam history I see a common pattern of a 0114 jam code but if I am not mistaken that would refer to the PS19 delivery sensor that it never reaches. Any ideas?
  2. #2
    Service Manager 5,000+ Posts
    copier tech's Avatar
    Join Date
    Jan 2014
    Location
    London
    7,560
    Rep Power
    182
    Re: Canon 2800 needs help
    Quote Originally Posted by Gina82 View Post
    Is this the Canon IR2800 mono machine?
    When the grease dries out in the fuser sleeve you get fixing unit jams usual for a motor to fail.
  3. #3
    Join Date
    Oct 2017
    Location
    Greenwood, MS
    98
    Rep Power
    14
    Quote Originally Posted by copier tech View Post
    Yes it is for the Canon IR2800 mono machine.The copy makes it out of the fuser successfull but when it is headed towards the exit it stops in the door every time.
  4. #4
    Senior Tech 100+ Posts
    Join Date
    Jul 2013
    Location
    Kumasi Ashanti
    185
    Rep Power
    0
    How often is does the jam occur? Every copying process or occasionally? In the meantime, don't forget to check the work of sensor flags. A weak spring on a sensor flag of previous sensor can be a culprit. Also check on clutch to see if it sticks or functions poorly. I hope you get round it.
  5. #5
    Service Manager 1,000+ Posts
    Brian8506's Avatar
    Join Date
    Feb 2009
    Location
    New Jersey
    1,597
    Rep Power
    63
    I've had to add an extra wrap to the fuser exit sensor spring. Check sensor flag operation
  6. #6
    Join Date
    Oct 2017
    Location
    Greenwood, MS
    98
    Rep Power
    14
    Do you think the fusing unit actuator is the issue even with the paper making it out of the fusing unit and the jam is a constant jam
  7. #7
    Field Supervisor 500+ Posts roho's Avatar
    Join Date
    Mar 2009
    Location
    Earth
    844
    Rep Power
    43
    Yes, very well could be as the flag is late to return to it's position as paper passes. The sensor being slow then gives the machine the impression the page is still over it, when it has moved on. The sensor arm at the fuser exit was a common problem, I cannot remember the jam code for that particular issue as I worked on these well over 15 years ago.
  8. #8
    Brian8506's Avatar
    Join Date
    Feb 2009
    Location
    New Jersey
    1,597
    Rep Power
    63
    Yes I do think they can still be the sensor flag. What is the jam code?
  9. #9
    Join Date
    Mar 2009
    Location
    Earth
    844
    Rep Power
    43
    He posted it was 0114
  10. #10
    Brian8506's Avatar
    Join Date
    Feb 2009
    Location
    New Jersey
    1,597
    Rep Power
    63
    Does the machine have a finisher? Entrance sensor on that can cause that if its bad or knocked out of place
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
