Originally Posted by
barber782
Yep the correct ppd installer was downloaded and installed.
The USB does work from my Windows laptop.
The other weird thing is that the ethernet port doesn't seem to work. Connected it both to the network and to my laptop you only get an steady orange light. Changed the network speed on the machine but nothing works. This is why I'm using USB.
When installing the postscript board I noticed an extra memory slot. Would this need to be installed possibly?
Sent from my VTR-L09 using Tapatalk
Try turning on the ethernet port in Service Program. SP5985-001 There qare also a number of settings in User Tools that can affect network function. If there is a setting for IEEE802.11 it must not be enabled as it turns off the normal function of the ethernet port.
When using the USB port, if the DD 6650 is set to Auto Detect the print language in the control panel it will recognize your Windows laptop but not the Mac. From the operator instruction manual.When printing with a USB connection to a Macintosh computer, the printer language does not
change automatically. Use the control panel on this machine to change the printer language to
[Auto Detect] or [PS] before printing
Bookmarks
