Page 1 of 2 12 LastLast
Results 1 to 10 of 17
  1. #1
    Service Manager 1,000+ Posts
    bizhub 200  touch screen adjustment
    brent's Avatar
    Join Date
    Nov 2008
    Location
    Kellogg Idaho
    1,136
    Rep Power
    44
    I cant seem to find this adjustment.. racking my brain thought I would ask here
    thanks all
    the reason I need this is because when we input fax numbers or letters it goes to the letter next to the intended one
    hoping the touch screen adj will work thanks
    brent
  2. #2
    RTFM!! 5,000+ Posts allan's Avatar
    Join Date
    Apr 2010
    Location
    Centurion
    5,400
    Rep Power
    153
    Re: bizhub 200 touch screen adjustment
    I have not done this in ages i think its a little like a B250 when it comes to that.
    Find the reset button on the back of the machine hidden behind a little cover press that to get the reset screen and the screen adjustment.
    I could be dead wrong.
    Not sure if you have to press "3" on the restart.
    Whatever
  3. #3
    brent's Avatar
    Join Date
    Nov 2008
    Location
    Kellogg Idaho
    1,136
    Rep Power
    44
    I remember that button.. it seems like in the set up on these machines this was one thing that was done.. its been too long ago
    I will look at the set up instructions thanks for the help
    brent
  4. #4
    Field Supervisor 500+ Posts
    Join Date
    Oct 2010
    816
    Rep Power
    45
    Try Stop-0-0-stop-0-2
  5. #5
    brent's Avatar
    Join Date
    Nov 2008
    Location
    Kellogg Idaho
    1,136
    Rep Power
    44
    thanks everyone. I finally found it in the maintenance mode. Screen. It fixed the problem
  6. #6
    Senior Tech 250+ Posts
    CraigW's Avatar
    Join Date
    Dec 2010
    417
    Rep Power
    33
    Hope it sticks..... those displays all fail sooner or later.
  7. #7
    Join Date
    Oct 2008
    Location
    Long Island, NY
    441
    Rep Power
    37
    Is there any way to get to this without touching "end" after the 0's? The top half of the screen is unresponsive even after replacing the touch panel.
  8. #8
    Join Date
    Jun 2020
    Location
    San Luis
    2
    Rep Power
    0
    Post Re: bizhub 200 touch screen adjustment
    Quote Originally Posted by mascan42 View Post
    Greetings from Argentina. I have the same oor simiar problem. Any suggestions?
    I´m looking for help solving a touchpad calibration issue on Bizhub.
    We were doing a maintenance procedure. We accessed touchscreen calibration option.
    We made a mistake during process:
    We pressed the calibration points that appear on screen during the calibration procedure in a wrong way (We clicked over the “arrows” instead of clicking over the “crosses” in the screen corners).
    After touching on the wrong places... we confirmed the calibration .
    It was working perfectly before, after wrong calibration we made, touch screen is totally miss calibrated.
    We can't go back to the calibration option to re calibrate it.
    If we repeat all steps to enter calibration screen, we get sucked on the last step, as follows:
    We press micro switch to reset. When dots [.] shows up at the center on the left-hand side of the screen, we enter [3] from the 10-Key Pad. We enter the 8-digit service code [00000000]. But we cannot touch [END] button, as the screen is miss calibrated.
    Is there any option to enter screen calibration without touching touch screen? Thank you very much
  9. #9
    Service Manager 5,000+ Posts tsbservice's Avatar
    Join Date
    May 2007
    7,154
    Rep Power
    346
    Quote Originally Posted by Nicoabd View Post
    Maybe with some trials you can guess/hit where to touch display instead of [END].
    I don't reply to private messages from end users.
  10. #10
    Service Manager 2,500+ Posts
    Join Date
    Sep 2005
    Location
    South Jersey
    3,860
    Rep Power
    133
    It's not that the screen needs adjustment or calibration. Those touch screens going bad was one of the most common problems on that series. You can get the aftermarket touch screen for around $50 USD.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
