Thanks Thanks:  0
Dislikes Dislikes:  0
Results 1 to 8 of 8
  1. #1
    Senior Tech 250+ Posts
    Join Date
    Mar 2010
    Location
    Lancaster Ohio
    258
    Rep Power
    31
    Konica bizhub 361 black and white 2403 code
    Konica bizhub 361 2403 code that comes up several times during a long copy run. I have replaced the part that spins the bottle and clean the sensors. I also got a 2603 and I change the developer and got rid of that, but the 2403 still comes up occasionally. Would you replace the whole toner Hopper or maybe start with the sensor. Appreciate any advice
  2. #2
    Join Date
    Mar 2010
    Location
    Lancaster Ohio
    258
    Rep Power
    31
    Re: Konica bizhub 361 black and white 2403 code
    [QUOTE=DOE;591897]Konica bizhub 361 2403 code that comes up several times during a long copy run. I have replaced the part that spins the bottle and clean the sensors. I also got a 2603 and I change the developer and got rid of that, but the 2403 still comes up occasionally. Would you replace the whole toner Hopper or maybe start with the sensor. Appreciate any advice[/ toner motor not toner Hopper
  3. #3
    Field Supervisor 500+ Posts Woxner's Avatar
    Join Date
    Jul 2011
    Location
    Felixstowe England
    784
    Rep Power
    41
    if you cleaned the hub good or replaced it and cleaned the sensors then yes the sub hopper. when i say hub it's the part that is the ring. they tend to wear and dont turn good
  4. #4
    Senior Tech 100+ Posts KMFLT3CH's Avatar
    Join Date
    May 2017
    162
    Rep Power
    21
    Run a sensor check on the toner bottle positioning sensor and a load check on the toner bottle motor:
    Service mode > state confirmation > sensor check > 57-3
    Then open the toner bottle door and physically spin the bottle clockwise. It should change from 0 to 1 as it passes over home position. If it stays on 1, the sensor is bad. You can vacuum it out and hope it works or replace it.
    Service mode > state confirmation > load check > 56-1 > press start
    The bottle should be spinning clockwise without hesitation. If there's any hesitation or it struggles, replace the toner supply unit/hopper and the toner supply motor together.
  5. #5
    Join Date
    Mar 2010
    Location
    Lancaster Ohio
    258
    Rep Power
    31
    Quote Originally Posted by Woxner View Post
    Someone gave me the part number for the sub Hopper and just look like the piece that turns the bottle which I have already replaced. Is the sub Hopper a different part than that
  6. #6
    CraigW's Avatar
    Join Date
    Dec 2010
    417
    Rep Power
    33
    The last 2403 I had used a length of conduit to reach the rear of hopper top left... and blasted with canned air. Never got a call back.
    On the 1s if you remove the FS you will see a removable metal plate that will let you access the sensor in that area.
  7. #7
    Join Date
    Mar 2010
    Location
    Lancaster Ohio
    258
    Rep Power
    31
    Quote Originally Posted by DOE View Post
    I replaced a part out of the toner motor and back that turns are you talking about in the toner Hopper itself the ring that the group fits into and then turns the bottle and if so is that the same part in like a Konica 350. I think they use the same style toner bottle. Also what's it take to get the sensors out of the machine is that quite a job
  8. #8
    Join Date
    Jul 2011
    Location
    Felixstowe England
    784
    Rep Power
    41
    50GA-3222 this is the hopper number
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
