Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    BizHub 751 Firmware
    Join Date
    Aug 2017
    Location
    Alexandria
    15
    Rep Power
    14
    BizHub 751 Firmware
    Hello,
    I am in need of Bizhub 751 firmware. Any help is greatly appreciated! Email below.
    technologyoutfitters@gmail.com
    Best Regards,
    Techout
  2. #2
    BizHub 751 Firmware
    Join Date
    Aug 2017
    Location
    Alexandria
    15
    Rep Power
    14
    Re: BizHub 751 Firmware
    Quote Originally Posted by Techout View Post
    Hello,
    Best Regards,
    Techout
    Current error code : C-C104
  3. #3
    Field Supervisor 500+ Posts Woxner's Avatar
    Join Date
    Jul 2011
    Location
    Felixstowe England
    783
    Rep Power
    41
    make sure you use 751 and not 601. thats why you have the code. sent you an email
  4. #4
    Service Manager 2,500+ Posts
    BizHub 751 Firmware
    Join Date
    Sep 2005
    Location
    South Jersey
    3,860
    Rep Power
    133
    If I'm thinking of the right model you have to update firmware in steps using a USB thumb drive? Few times I did it there was always an issue. Not as bad as the CF card recently discussed here but still the beginning stages of using USB for F/W updates.
  5. #5
    Service Manager 1,000+ Posts
    BizHub 751 Firmware
    Join Date
    Mar 2012
    1,220
    Rep Power
    50
    Quote Originally Posted by copyman View Post
    It is CF card, probably one of the more finicky ones I have dealt with too. It also has an additional CF card for system software too.
    You have to use the correct CF card as well...these work:
    DO NOT FORMAT and you also need the loading tool.
    As Woxner noted:
    HTML Code:
    DescriptionC-C104 or C-C111 when updating Printer Controller firmware.Solution CAUSE: Printer board was updated with bizhub 751 firmware.    SOLUTION: To correct:  1. Enter ISW update mode, press Board Type Selection and select All Printer.  2. Next press File Selection. The shown file name should start with  57ba  which is the correct naming for bizhub 601.Continue the update procedure.  3. However, if the file name starts with  57aa , wrongfirmware (for bizhub 751) is indicated. Please stop update procedure.   a. Leave ISW update mode and go to DipSW setting mode.   b.Set DipSW 32-1 to 0.  c.Return to ISW update mode.   d.Under File Selection two files are visible now. Select the file for bizhub 601 ( 57ba ) and start update procedure.   SPECIAL NOTE : Solution contribution by KM Europe (BEU)
    DescriptionC-C104 error code at power on and unable to make any selections in service mode. Display stays at Konica Minolta when attempting a trouble reset.Solution CAUSE: Printer control board has the incorrect firmware and the installed fax kit and/or HDD are locking up service mode.    SOLUTION: To correct perform the following:    1. Physically remove the fax kit and HDD.  2. Enter service mode and set soft switch 32-1 to a 0.  3. Perform ISW and select the correct file for model, 601 starts with 57BA and 751 starts with 57AA.  4. Set soft switch 32-1 back to 1 after completing.
    EDIT: text wrapping isn't working it looks like copy and paste the above into a word processor...
  6. #6
    Join Date
    Jan 2009
    Location
    UK
    828
    Rep Power
    50
    USB flash drive to update the firmware on this model.
  7. #7
    BizHub 751 Firmware
    Join Date
    Mar 2012
    1,220
    Rep Power
    50
    Quote Originally Posted by tech51 View Post
    Absolutely correct. I even checked the SM before posting, must have read something backwards.
    There is a "base firmware" CF card installed on the MFP--shouldn't be related to the OP though...
  8. #8
    Join Date
    Oct 2019
    Location
    Punjab Faisalabad
    5
    Rep Power
    0
    Hello,
    Best Regards,
    Techout
    Hello friends. I also need Bizhub 751 firm ware and its installation method. plz help me i need it urgently.
    thanks
    email id: master72gb@gmail.com
  9. #9
    Join Date
    Oct 2019
    Location
    Punjab Faisalabad
    5
    Rep Power
    0
    Quote Originally Posted by Woxner View Post
    Hello friends. I also need Bizhub 751 firm ware and its installation method. plz help me i need it urgently.<br>thanks<br>email id: master72gb@gmail.com
  10. #10
    Join Date
    Oct 2019
    Location
    Punjab Faisalabad
    5
    Rep Power
    0
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
