Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Trusted Tech 50+ Posts
    Join Date
    Jul 2014
    59
    Rep Power
    20
    C224e draw issues
    We ve got a C224e with draw 1 problems.It randomly shows A4 as 81/2 by 11 then ??? and it does not recognize paper in the tray but the light does not go on, but it does when you open the draw. We changed the tray,transport and the size sensor at the back.no joy.Thanks for any suggestions.
  2. #2
    Join Date
    Oct 2018
    19
    Rep Power
    12
    Re: C224e draw issues
    your cable may have gone
    A161N10N01
    It is the reference of the drawer 1 usually broken
  3. #3
    Service Manager 2,500+ Posts
    C224e draw issues
    Join Date
    Sep 2005
    Location
    South Jersey
    3,851
    Rep Power
    133
    Quote Originally Posted by gere1 View Post
    A161N10N01
    Huh. What cable? Think you have the machines mixed up. Tray 1 in the C224 is a 500 sheet tray. The C654/754 have LCC's that use a cable but they are labeled 3 & 4. The old bizhub 601 had the LCC's at top and were tray 1 & 2
    I've work on many Bizhubs and only cables I'm aware of are for LCC's, finishers & scanner/lamp assy. Never a regular paper tray.
    As for the posters original question, sounds like the guides that slide are not locking in place all the way. You have to try and get the gudies to lock deeper into size slots. And as last resort if customer only uses the tray for one size you could put small self tapping screw somewhere to hold guides from moving. Also could manually set the tray to the size instead of auto.
  4. #4
    IT Manager 10,000+ Posts bsm2's Avatar
    Join Date
    Feb 2008
    Location
    Biden 2024
    25,972
    Rep Power
    335
    Take it off auto and set draw size
  5. #5
    Service Manager 5,000+ Posts tsbservice's Avatar
    Join Date
    May 2007
    7,137
    Rep Power
    346
    Quote Originally Posted by copyman View Post
    This cable - Key 1 :
    I don't reply to private messages from end users.
  6. #6
    C224e draw issues
    Join Date
    Sep 2005
    Location
    South Jersey
    3,851
    Rep Power
    133
    Quote Originally Posted by tsbservice View Post
    I guess a language difference. We call that a wiring harness with connectors. Never in 45 yrs in this biz have I heard it called a cable.
    And this is what Konica Minolta calls it: A161N10N01 "Paperfeed Wiring /Rear" EA 7.87
  7. #7
    Certified Konica Expert 2,500+ Posts
    C224e draw issues
    Synthohol's Avatar
    Join Date
    Mar 2016
    Location
    North Jersey
    4,981
    Rep Power
    217
    check the guides when paper is in it, when the customers load the drawers and close them like they are bowling for a strike, the guides shift back and screw up the auto size function.
    the 8.5 or 11 should line up with the edge of the paper, not 3mm+ towards the rear.
    Also don't ask me for files without a contributor badge.
  8. #8
    Join Date
    Jul 2014
    59
    Rep Power
    20
    We changed the whole draw so it can t be the guides,we ve taken off auto but cant find how to manually set paper size and orientation.And we still have the issue of it not recognizing paper in the draw, and the orange light going on whan you open the draw.
  9. #9
    Field Supervisor 500+ Posts
    Join Date
    Dec 2009
    681
    Rep Power
    60
    Almost 100% sure its problem in in draw paper size sensor wiring,have same case recently.
  10. #10
    Senior Tech 250+ Posts
    C224e draw issues
    DigiMan's Avatar
    Join Date
    Jan 2013
    Location
    In a gadda da vida
    262
    Rep Power
    27
    +1 on the wiring,changed it 1 week ago for the exact same issue.
    I don't like the new copier I just bought. It says "put face down" but every time I do it, it blinds my eyes.
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
