Page 1 of 3 123 LastLast
Results 1 to 10 of 24
  1. #1
    Join Date
    Jan 2020
    Location
    Neamt
    3
    Rep Power
    0
    Bizhub 363 toner not adhering
    Hello everyone!
    I have a problem with one of my copiers, after i rebuild the fuser unit and changed the developer.
    When i start the copier, in the morning, on the first prints/copies i make, the toner is not adhering right. What i noticed is if i print 1-2 gradation pattern test page, everything gets back to normal.
    On the fuser unit i changed the upper fuser roller and pressure roller with aftermarket parts, but did not change thermistors, they looked good to me.
    I also changed the fusing temperature to +10, still same.
    Should i also change the thermistors or what could be the problem to this unit?
    Regards!
  2. #2
    RTFM!! 5,000+ Posts allan's Avatar
    Join Date
    Apr 2010
    Location
    Centurion
    5,400
    Rep Power
    153
    Re: Bizhub 363 toner not adhering
    Did you install the springs and other parts in the fuser correctly?
    Crappy toner will do that...
    Whatever
  3. #3
    Join Date
    Jan 2020
    Location
    Neamt
    3
    Rep Power
    0
    Yes, i installed them correctly. Could it be that the parts i installed were not such good quality?
    Could bad thermistor generate this kind of fault?
  4. #4
    Service Manager 1,000+ Posts femaster's Avatar
    Join Date
    May 2011
    Location
    A Small City in MI
    1,282
    Rep Power
    97
    Quote Originally Posted by phalemi24 View Post
    This is most likely the case. My company is buys crap parts from China to rebuild these units, and us techs that are stuck rebuilding and installing these things have nothing but problems. Generally if we just replace the upper roller, and set the temp to +10, we are OK with LEF, but SEF still won't stick. We've never had luck with aftermarket lower rollers, those seem to be a lost cause.
    We've gone through a number of revisions (experiments) to try and get these junk parts to work, and all of our success has had to do with increasing the pressure between the two rollers. Our first few experiments had too much pressure and proved detrimental to the rollers. Ended up with LOTS of torn uppers from too much tension.
    I believe we have finally found a happy middle ground between increased pressure and not killing the rollers. We have been quite successful with threading a screw into the metal frame (frame, not tension arm) in the slot where the spring attaches. This takes up a little more of the space so the anchor point of the spring is further back and increases the pressure. We use the same type of screw that is used to hold the end caps onto the fuser, (course thread with wide head). I could probably get you a picture of it tomorrow when I'm at the office and add it to this thread.
    My only concern is that this might not help you out because you have the generic lower roller in there. As I stated earlier, we have never had luck with them. Maybe they are too soft or something, not sure, but they just don't work.
    A Ricoh Service Tech for 7 year. A Konica Minolta Service Tech for 7 years. Now, KM service manager for 3 years.
  5. #5
    Service Manager 2,500+ Posts
    Join Date
    Sep 2005
    Location
    South Jersey
    3,860
    Rep Power
    133
    Like others have said
    1) aftermarket toner
    2) aftermarket rollers
    3) always change thermistors, toner build up on thermistors is what causes the cuts in UFR to begin with. Don't even try to clean them, before you get the baked on toner off you will destroy the film on thermistors! So automatically change with new UFR. I use the old bushings & bearings and get at least 2 lifes out of LFR. Some customers are using aftermarket toner and I up the temp +10.
    Think I heard someone on this forum saying a lot of his Biz 223 series fuser lamps were going bad or getting weak. He was asking to buy used lamps as parts aren't sold for the fuser as you know.
    The best aftermarket UFR I've used to date is from a member on this forum, Hans from Germany. I get them from someone he sells to here in USA. Nice hard coating. Like that frying pan commerical where they use an electric mixer on the pan surface. Ha-ha
  6. #6
    Join Date
    May 2011
    Location
    A Small City in MI
    1,282
    Rep Power
    97
    copyman,
    Unfortunately, I don't have a say in what the company buys, so, aftermarket garbage is what we get to deal with. And yes, they buy the generic toner as well. The increase in pressure has helped us deal with this generic garbage. It's sad when a tech has to hack the OEM design to make the generic crap work, but such is the life we lead here.
    We rarely replace the thermistors as when the fuser receives it's very first rebuild, we gently clean and then apply teflon (PTFE) film tape to them, which then keeps them clean. During the next rebuild we remove the tape and reapply fresh. Some of these fusing units have been through 6+ rebuilds, with pretty much the only part ever getting replaced being the upper roller. Bearings and bushings get high temp grease applied and they stay nice and quiet.
    And yes, I can confirm that the bulbs in these are VERY poor and frequently burn out. It's gotten to the point where we are scavenging and splicing in the 200/250/350 bulbs as they last forever. Splice them into the harness of the 363 fuser and swap out the bulb holder brackets (they fit perfectly in the 363 fuser body). Just have to make sure that you have the wiring correct for the upper and lower bulbs. They have to be wired to the correct upper and lower bulb connection on the original harness, otherwise you end up with fuser service codes.
  7. #7
    Join Date
    May 2011
    Location
    A Small City in MI
    1,282
    Rep Power
    97
    Sorry it took so long for me to get back with the picture. Here is a picture of what I was talking about with the screw and the spring. You will need to insert the spring and have it turned to the back side of the fusing framework so it's out of the way when you install the screw. You have to install the spring first, as you will never get it in there once the screw is in. Then just rotate it towards the front and attach it to the tension arm.
  8. #8
    Field Supervisor 500+ Posts Woxner's Avatar
    Join Date
    Jul 2011
    Location
    Felixstowe England
    783
    Rep Power
    41
    easy way to clean thermisters is to use a highlighter marker. its takes the toner off real easy
  9. #9
    Join Date
    Apr 2010
    Location
    Centurion
    5,400
    Rep Power
    153
    The aftermarket thermistors i get is better than the OEM stuff and does not scratch the rollers.
    Been using aftermarket uppers, lowers and picker-pawl for to long now never needed any modification.
    Even if the lower looks like a raisin it still works ok, so i almost never change them out with no issues.
    So not sure where you guys get this out of spec stuff from.
    Bad toner caused this issue before. Where i had to vacuum out the hoppers and run the toner out of the developer on dozens of machines.
    Toner does not fuse properly even with increased heat.
    Whatever
  10. #10
    Join Date
    Apr 2010
    Location
    Centurion
    5,400
    Rep Power
    153
    Quote Originally Posted by Woxner View Post
    Will give that a shot thanks.
    Whatever
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
