Results 1 to 6 of 6
  1. #1
    Senior Tech 250+ Posts
    Konica Minolta c452 P5 P21 P28
    mearmi's Avatar
    Join Date
    Oct 2010
    339
    Rep Power
    31
    Konica Minolta c452 getting codes P5 P21 P28. Image is with Yellow Background.
    Replaced all 3 imaging units but still same.
    Please advise
  2. #2
    RTFM!! 5,000+ Posts allan's Avatar
    Join Date
    Apr 2010
    Location
    Centurion
    5,397
    Rep Power
    152
    Re: Konica Minolta c452 P5 P21 P28
    The old laser or ribbon cable issue?
    Is that background a nice consistent tone?
    With or without a border?
    Whatever
  3. #3
    Service Manager 5,000+ Posts tsbservice's Avatar
    Join Date
    May 2007
    7,149
    Rep Power
    346
    Hi mearmi, attached images as always will help a lot. We are mostly contributors not forecasters.
    I don't reply to private messages from end users.
  4. #4
    mearmi's Avatar
    Join Date
    Oct 2010
    339
    Rep Power
    31
    Quote Originally Posted by tsbservice View Post
    Please find the attached image and advise.
    Attached Images Attached Images
  5. #5
    Join Date
    Apr 2010
    Location
    Centurion
    5,397
    Rep Power
    152
    Quote Originally Posted by mearmi View Post
    Did you try the connectors and ribbon cables?
    HV to the yellow IU could be irregular because of a bad connection or even a bad HV board but never changed one.
    Would not like to think its the laser but that is an easy thing to test.
    Remove and reinstall the HV board or replace it if you wish.
    One way to trouble shoot is to swap HV leads between yellow and magenta.
    Have done that to trouble shoot on other models but not on a C452.
    Whatever
  6. #6
    Join Date
    May 2007
    7,149
    Rep Power
    346
    Most likely it's PH unit. To test, temporarily block yellow PH window. If the background goes away, replace the P/H Unit assembly.
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
