Page 1 of 2 12 LastLast
Results 1 to 10 of 19
  1. #1
    Join Date
    Mar 2020
    Location
    antelope
    10
    Rep Power
    0
    Konica Minolta bizhub 4750 error code E301
    I have few Konica Minolta bizhub 4750 printers and on all of them I have error code E301(000.00) as soon as i plug in network to it. Anyone had problem like that?
  2. #2
    Certified Konica Expert 2,500+ Posts
    Konica Minolta bizhub 475  error code E301
    Synthohol's Avatar
    Join Date
    Mar 2016
    Location
    North Jersey
    4,990
    Rep Power
    217
    Re: Konica Minolta bizhub 475 error code E301
    E301 Referring incorrect memory
    reseat the ram or maybe if the additional ram is the wrong type?
    if not the copier then maybe the wrong driver is being used to print?
    Konica is down so i cant even get a solution if one exists.
  3. #3
    Trusted Tech 50+ Posts
    arahael's Avatar
    Join Date
    Mar 2013
    94
    Rep Power
    23
    Go Admin setting>Network>SSDP ? Broadcasting? > Disable it.
    Works on xx4 series
  4. #4
    Master Of The Obvious 10,000+ Posts
    blackcat4866's Avatar
    Join Date
    Jul 2007
    Location
    Lapeer, Michigan
    22,471
    Rep Power
    463
    I'm just going to say that I wish you luck. We placed (4) bizhub 4052's that lock up the moment they are plugged into the endusers network. They do not lock up on our network, or any other network tested. If there is a solution, KM could not come up with it.
    If my opinion carries any weight (and it usually does not) it seems like the only feasible solution to substitute Lexmarks. Yes, I know it's basically the same engine, but the Lexies don't lock up.
    I'll be watching the comments. =^..^=
  5. #5
    Service Manager 10,000+ Posts
    Phil B.'s Avatar
    Join Date
    Jul 2016
    Location
    Raleigh NC
    22,790
    Rep Power
    661
    Quote Originally Posted by blackcat4866 View Post
    blackcat4866,
    With ALL due respect Sir I strongly DISAGREE with this statement
    I Consider YOU Sir, one of the MOST on point users with your recommendations .. You Sir, have a knowledge I only wish I could attain ..
    PLEASE Brother NEVER sell yourself short in any way shape or form. I know you are a humble soul.. but don't sell yourself short.
    Phil B.
  6. #6
    Join Date
    Aug 2020
    Location
    New Jersey
    5
    Rep Power
    0
    turn on the machine with the network cable unplugged.
    if it starts up fine, clear the print queue.
    make sure it is running the latest firmware, there are a plethora of print job related bugs that cause this.
  7. #7
    Senior Tech 100+ Posts
    Join Date
    Feb 2018
    Location
    Kankakee, Il
    177
    Rep Power
    17
    We had a couple of 4750s doing this. Never did find a fix. KM couldn't figure it out. Installed different machines for the customer and all is well. Put the 4750s in another location. small companies. working ok
  8. #8
    Service Manager 1,000+ Posts Bix's Avatar
    Join Date
    Apr 2018
    Location
    Berlin
    1,421
    Rep Power
    39
    Hi, the bizhub 4050/4750 is the first start of Konica Minolta software integration into Lexmark. If you notice, the settings are similar to Konica Minolta printers but I personally consider a bad copy bad. A good integration of the Konica Minolta software I found it only in the next model, therefore in bizhub 4052.
    I have seen several bulletins on network problems and E301/E304. The best advice is to update the firmware to the latest version. I have seen several bulletins on network problems and E301. The best advice is to update the firmware to the latest version. Another bulletin suggests "Change the network speed setting to automatic. (Default: 100 Mbps half duplex)"
    Other solution:
    1. Install the firmware that fixes the issue.
    2. Change to [ON] if [Rank C] of [Internal Error. Auto Cancel] in Service menu is set to [OFF].
    Procedures: [Service Mode]> [System 2]> [Internal Error. Auto Cancel]> [Rank C]
    Change to [ON] if it's set to [OFF]. (Default: ON)
    Supplementary information:
    The interval time from Error occurrence to automatic reboot can be changed by the following Software Switch setting.
    291 bit0: [0]: 60 seconds to automatic reboot. (Default)
    [1]: 10 seconds to automatic reboot.
    [Fixed firmware]
    bizhub 4750/4050
    -> Install A6F730G0705-W99, A6F730G0705-999, or later.
  9. #9
    Join Date
    Mar 2020
    Location
    antelope
    10
    Rep Power
    0
    Thanks, it always starts up fine without network cable attached. in fact it works fine on USB only.
    Anyway, Do you know how to update firmware on it if there is service password that is not default and I don't know a new one?
    Quote Originally Posted by Akshay_M View Post
  10. #10
    Phil B.'s Avatar
    Join Date
    Jul 2016
    Location
    Raleigh NC
    22,790
    Rep Power
    661
    Quote Originally Posted by serzhmarchuk View Post
    that info is in the service manual...
    IMHO no tech worth his salt will go to a machine WITH OUT one ...
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
