Results 1 to 6 of 6
  1. #1
    Senior Tech 100+ Posts
    Join Date
    Feb 2010
    218
    Rep Power
    0
    Konica 6501 No toner bottle Detected
    Greetings Fellow techs,
    Heres one for you, had a client who recently had to change a cyan toner bottle, then says after running a bit its said toner bottle not detected, no errors just toner bottle not detected, then the reseated the toner bottle the message went away for a few copies, then returned for cyan, then black, then maGENTA, the yellow. now none of the bottles are detected. reseated and shut off machine several time, and got nothing, just says no toner bottle detected.
    anyone heard of this happening?? possible a wire short???. or possible board. i found photo sensor for the door also a toggle switch. i am guessing it the photo sensor. but ordering one, just to see.
    any help or insight, please.
    thanks.
  2. #2
    Certified Konica Expert 2,500+ Posts
    Synthohol's Avatar
    Join Date
    Mar 2016
    Location
    North Jersey
    4,988
    Rep Power
    217
    Re: Konica 6501 No toner bottle Detected
    process door (BF toner reservoirs) not slammed closed hard enough or connector dirty?
  3. #3
    Field Supervisor 500+ Posts
    tulintron's Avatar
    Join Date
    Jul 2014
    Location
    Belo Horizonte, Minas Gerais
    641
    Rep Power
    32
    Quote Originally Posted by Arcadian View Post
    thanks.
    Exactly. In the toner supply port there is a photosensor and a switch. However, if there is no lock between the hinge axis and the cover, the cover is unable to actuate the switch, causing supply failure.
    Nothing like day after day
  4. #4
    Join Date
    Feb 2010
    218
    Rep Power
    0
    Quote Originally Posted by Synthohol View Post
    worth a try, i ordered a door photo sensor 08AA 8551 2 PHOTO SENSOR
    going to see if it works be here in a few days
  5. #5
    tulintron's Avatar
    Join Date
    Jul 2014
    Location
    641
    Rep Power
    32
    you can also test it using I / O Mode Check
  6. #6
    tulintron's Avatar
    Join Date
    Jul 2014
    Location
    641
    Rep Power
    32
    Enviado do meu iPhone usando Tapatalk
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
