Page 1 of 2 12 LastLast
Results 1 to 10 of 19
  1. #1
    Service Manager 2,500+ Posts
    C3350 swapping IU's ???
    Join Date
    Sep 2005
    Location
    South Jersey
    3,860
    Rep Power
    133
    Has anyone had success swapping the image units from one C3350 to another of same model? I always get a C255X code. I've even tried a reset chip on a black unit and still got a C255X code but did reset life back to 100%.
    Is there a way to use image unit from another machine? I have a few low meter parts machines I would like to use the image units on my contract customers.
    Thanks in advance
  2. #2
    Master Of The Obvious 10,000+ Posts
    blackcat4866's Avatar
    Join Date
    Jul 2007
    Location
    Lapeer, Michigan
    22,471
    Rep Power
    463
    Re: C3350 swapping IU's ???
    Correct. I have had no success swapping used IU's, regardless of usage. =^.^=
  3. #3
    Service Manager 1,000+ Posts
    Join Date
    Mar 2012
    1,220
    Rep Power
    50
    I don't know, but couldn't you just swap the chips?
    That said, I don't know if you can bypass EOL on IUs for that model.
  4. #4
    Join Date
    Sep 2005
    Location
    South Jersey
    3,860
    Rep Power
    133
    Quote Originally Posted by Synaux View Post
    Thanks for the reply....
    Funny you mention that, I tried using the chip from the bad original IU and after a week or two the customer calls with code. For instance this most recent time I bought machine from wholesaler with 18k, everything was great except some faint magenta lines. I had a parts machine in shop with only 10k because of broken screen so swapped mag IU using the chip from "original" unit with faint lines. Worked great for 50+ test pages in shop, delivered machine and two weeks later C2554 code. My thinking is machine must read the dev levels along with the factory chip and after some usage it doesn't stay at proper level and throws code. Machine will reset and after printing a few pages it throws code again.
    Ordered a new Mag IU and be done with it this time. Just asking so I know in future if I can do it. Was hoping something simple like adj TCR or something to get it to work.
  5. #5
    Senior Tech 250+ Posts
    Join Date
    Jul 2013
    305
    Rep Power
    30
    Many years ago on the blackwhite devices you had to reset the developper values before change.
    I think its not possible but you can check to change after a stabilisation/initialisation.
  6. #6
    Service Manager 5,000+ Posts tsbservice's Avatar
    Join Date
    May 2007
    7,145
    Rep Power
    346
    It's automated you cannot change those values manually. That said maybe new(aftermarket) IU chip may help to initialize values and use rest life of used but good ones IUs.
    I don't reply to private messages from end users.
  7. #7
    Join Date
    Sep 2008
    Location
    Flat Rock Michigan
    1,047
    Rep Power
    49
    Quote Originally Posted by occus View Post
    this is how i get used to work initialize and stabilize, check tcr and correct by doing manual toner add or test prints to tone up or de tone, do gradation settings till readings are within specs rerun stablize . reboot check tcr run some heavy coverage tests recheck tcr, if copier is happy with the used unit it will maintain a good toner to carrier ratio, if its going nuts you will need to fool around with hv settings, (if you don't know witch settings to change you shouldn't be fooling around with used supplies anyways)
    on the 3350, if you have a complete donor machine you can swap all image units out and trade the counter chips on the mfp from the donor into target unit.(again if this is Greek to you, leave it alone.)
  8. #8
    Join Date
    Sep 2005
    Location
    South Jersey
    3,860
    Rep Power
    133
    Quote Originally Posted by Albonline View Post
    Thanks, I will try your system next time I need to replace IU. Ha-ha not Greek to me. Been a tech for 40+ years, mostly Kon/Min. Not much exp with the small models.
    Don't think I would ever want to mess with HV settings. Before that extreme you bite the bullet and buy new IU!
    Might try chips from a different supplier.
    Surprised this small model IU's would be so much trouble because no problem swapping around consumables with most of the bigger Kon/Min models.
  9. #9
    Hansoon's Avatar
    Join Date
    Sep 2007
    3,200
    Rep Power
    95
    Cause they are rebadged and not made by KonicaMinolta.
    Anything other than the A3 size machines is weak and often problematic.....
    Hans
    " Sent from my Intel 80286 using MS-DOS 2.0 "
  10. #10
    Join Date
    Sep 2005
    Location
    South Jersey
    3,860
    Rep Power
    133
    Quote Originally Posted by Hansoon View Post
    Hans
    I know the small B&W models are made by other OEM's like the Biz 25e is a Muratec & 4750 is Lexmark but are you sure the small color machines aren't made by Konica Minolta or who ever makes their color models (NEC?)? The C3350 etc look just like a mini version of the "4" series and another reason I thought it was Kon/Min made .
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
