Can i use a 5500i Document feeder on 5501i ?
I tried to swap them ( i swaped a DP from working 5500i ) to a 5501i which dp was problematic ( when i put paper on it it recogniced them (green light on DP) , when i open a DP cover it recognized it ) but when i try to copy from DP message .. copying appears and blocks. If during this time i open a DP cover , it copies but from glass and paper jam message) . Now i suspect it's the PWB ISC i checked part list and PWB from 5501 has different code from 5500. Can i swap them?
Or if the problem is not PWB any idea?
Did you re-load the firmware?
ANY time you install a different board you must re-load firmware so that there are compatible levels of firmware. =^..^=
Try running the document processor independently in mode u203
Does the DP function during scan and send?
Just to clarify: Kyocera products are unique in defining a "DF" as a document finisher, and a "DP" as a document processor. =^..^=
Bookmarks
