Page 1 of 2 12 LastLast
Results 1 to 10 of 20
  1. #1
    Technician tec966's Avatar
    Join Date
    Mar 2009
    38
    Rep Power
    31
    6053ci Print issue
    Good morning,
    we ask you if you have any suggestions for the attached problem (white vertical stripes)?
    You can see it well in full solid colors.
    We have already replaced these parts:
    all the dev unit and drum unit
    LSU
    HVT Board
    Transfer Belt unit
    Thanks in advice !
    Attached Images Attached Images
  2. #2
    Owner/Service Manager 1,000+ Posts
    6053ci Print issue
    tmaged's Avatar
    Join Date
    Oct 2008
    Location
    Center of my Universe
    1,763
    Rep Power
    60
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
  3. #3
    Field Supervisor 500+ Posts
    6053ci Print issue
    dalewb74's Avatar
    Join Date
    Feb 2018
    899
    Rep Power
    29
    Re: 6053ci Print issue
    did you run the maintenance modes afterwards? so that it knows it has new parts. did you run any calibrations?
  4. #4
    Senior Tech 250+ Posts PrintWhisperer's Avatar
    Join Date
    Feb 2018
    Location
    Wild West
    434
    Rep Power
    30
    Looks like gear lash from worn drive pack.
    Run U89 grey print of cmyk and see if pattern is less prominent in K vs others. (Different drive motor/gear train)
  5. #5
    Join Date
    Aug 2011
    581
    Rep Power
    57
    Looks like wrong DV voltages.
    All needed adjustments would done?
    Please share U000/ maintenance report (*.txt file)
    Check U140
  6. #6
    Join Date
    Mar 2009
    38
    Rep Power
    31
    Quote Originally Posted by PrintWhisperer View Post
    Thanks for your reply, the thin vertical lines are both on colors and gray, we did a U021 reset and all the MK adjustment...(U952 etc..)
  7. #7
    Join Date
    Feb 2018
    Location
    Wild West
    434
    Rep Power
    30
    Quote Originally Posted by tec966 View Post
    Perhaps Paper drive is affected and not image drive.
    Waste toner auger is driven from PF drive. Check for build-up or difficult rotation of auger drive gear where PF drive engages, the WT clogging is common issue.
  8. #8
    Join Date
    Mar 2009
    38
    Rep Power
    31
    The issue is visible on the belt, so i think is not a papre feed problem...
  9. #9
    Join Date
    Aug 2011
    581
    Rep Power
    57
    It is difficult to analyse from the shared picture.
    Please share U089/ color belt + U000/ maintenance report.
    If i would called for help, i always ask for reports and internal printouts..
    What do you think why it would implemented from japanese engineers?
    It's easier for analysing problems like yours.
  10. #10
    Join Date
    Feb 2018
    Location
    Wild West
    434
    Rep Power
    30
    Good info to include in original post (panic stop observation), this is in area before transfer operation (underside) or after transfer (topside)?
    Get those U89 samples and Maint. Report. (Help us help you)
    Still, check Waste toner bottle to insure it rotates while engine cycles with WT door switch cheated. Common issue of WT bottle non-rotation can clog TX belt cleaner as well as rear auger.
    Ensure TX belt setting procedure is performed (MM469 Belt Initialize)
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
