Results 1 to 10 of 10
  1. #1
    Owner/Service Manager 1,000+ Posts
    P2040dw add paper to cassette
    tmaged's Avatar
    Join Date
    Oct 2008
    Location
    Center of my Universe
    1,763
    Rep Power
    60
    https://www.copytechnet.com/forums/k...sette-1-a.html
    I found this thread, but I don't think mine is doing the same thing with the MP tray. It's not a paper size/media type issue. Seems to be mechanical, but I've only seen it do it once. It's happend a couple of times according to my customer. Firmware is up to date, latest KX driver. Same print engine as the 2540/2635mfp.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
  2. #2
    Senior Tech 1,000+ Posts kuby's Avatar
    Join Date
    Oct 2007
    Location
    Texas
    1,272
    Rep Power
    54
    Re: P2040dw add paper to cassette
    Don't know what issue you are having, but make sure when you are using the MP tray to put more paper in it than you need so the sensors pick up that there is paper in it and what size.
  3. #3
    Field Supervisor 500+ Posts
    Join Date
    May 2009
    Location
    Concord, NH
    770
    Rep Power
    53
    When tray one is inserted, is the paper plate being released? Have had a couple of these on 2540's where the latch does not release the paper plate and the machine does not see paper in the tray. It can be intermittent. I had a case where you could insert the tray ten times and then the next time the paper plate would not be released resulting in a add paper indication. Most times add a small amount of grease on the nylon catch and the paper plate latch will resolve it. Other cases we "reformed" the L shaped latch on the plate to get it to work reliably. What is baffling is this is the same design used on many previous models that work flawlessly. My guess is they changed the metal of the paper plate that deforms causing the problems.
  4. #4
    Senior Tech 250+ Posts PrintWhisperer's Avatar
    Join Date
    Feb 2018
    Location
    Wild West
    434
    Rep Power
    30
    Ask your Kyocera Rep for SB I137, a rather complicated mechanical fix of the lift plate 'hook' binding due to burrs in manufacture which is identified for the following units:
    P2040dw (120v Americas) prior to VD28317628
  5. #5
    Master Of The Obvious 10,000+ Posts
    blackcat4866's Avatar
    Join Date
    Jul 2007
    Location
    Lapeer, Michigan
    22,471
    Rep Power
    463
    Quote Originally Posted by PrintWhisperer View Post
    Sounds like something I could fix with a flat file. =^..^=
  6. #6
    Join Date
    Feb 2018
    Location
    Wild West
    434
    Rep Power
    30
    Quote Originally Posted by blackcat4866 View Post
    LOL….actually that’s in there. However some parts can get deformed and the (long) bulletin has nice diagrams.
  7. #7
    tmaged's Avatar
    Join Date
    Oct 2008
    Location
    1,763
    Rep Power
    60
    Thank you, I was able to find it with the bulletin number. Astea is a less than user friendly site. I'd also tried looking under the MFP version of that engine on the Service Navi. I just double checked again, and that bulletin isn't listed there. It was released after the last time it was updated.
    My serial number is VD207xxxxx, so it shouldn't apply ? I guess I should still check to see it the plate is bent even though it shouldn't have the burrs.
    Hope that helps !
    -Tony
    www.dtios.com
  8. #8
    Join Date
    May 2009
    Location
    Concord, NH
    770
    Rep Power
    53
    tmaged you would be wise to check the plate. If it was just burrs on the plate latch, why does it take thousands of pages for the symptom to show up?? If it were just burrs on the latch it would exhibit the problem long before tray one was opened and inserted hundreds of times. Our typical failure with this problem occurs in the 150,000 to 200,000 range. That indicates a metal fatigue problem not a burr. I have toyed with the idea of taking a paper lift plate from a m2535 and putting it in a M2540 cassette to see the results, I think I will do it.
  9. #9
    Join Date
    Jul 2007
    Location
    Lapeer, Michigan
    22,471
    Rep Power
    463
    Quote Originally Posted by Santander View Post
    ... I have toyed with the idea of taking a paper lift plate from a m2535 and putting it in a M2540 cassette to see the results, I think I will do it.
    I'll be interested in the results. =^..^=
  10. #10
    Join Date
    Feb 2018
    Location
    Wild West
    434
    Rep Power
    30
    tmaged you would be wise to check the plate. If it was just burrs on the plate latch, why does it take thousands of pages for the symptom to show up?? If it were just burrs on the latch it would exhibit the problem long before tray one was opened and inserted hundreds of times. Our typical failure with this problem occurs in the 150,000 to 200,000 range. That indicates a metal fatigue problem not a burr.....
    You are correct in that the burrs on the plate hook initially occasionally catch and the lift plate sits out of position, binds on lift and may not drop so can cause jams or bind on removal.
    The stress deforms the hook and over time the entire lift plate.
    It's all in there, even the lift plate PN
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
