Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1
    Field Supervisor 500+ Posts
    MP301 SMB scan to Win7 authentication error
    Join Date
    Oct 2007
    Location
    San Diego, CA
    969
    Rep Power
    47
    I set this up today on 4 Win7 computers, 3 of them went fine.
    The last one keeps giving me Authentication error when scanning.
    I have the right user name and password, logged out and back in to verify, AND just in case I created a new user: scanner with password: password
    and same error with that.
    These are all on the same network and set up exactly the same.
    Is there some simple setting I'm missing?
  2. #2
    IT Manager 10,000+ Posts bsm2's Avatar
    Join Date
    Feb 2008
    Location
    Biden 2024
    26,017
    Rep Power
    336
    Re: MP301 SMB scan to Win7 authentication error
    Double check you sharing and security settings
    Is it wireless or hardwired. Hardwired make sure you disable the wireless.
  3. #3
    Retired 10,000+ Posts
    slimslob's Avatar
    Join Date
    May 2013
    Location
    Bakersfield, CA
    34,242
    Rep Power
    992
    If the one that that is giving the error is using wireless through a USB wireless dongle, that could be the problem. I have encountered USB wifi adapters that will not allow file sharing.
  4. #4
    Join Date
    Oct 2007
    Location
    San Diego, CA
    969
    Rep Power
    47
    Quote Originally Posted by slimslob View Post
    thanks, I will have to check that
  5. #5
    Join Date
    Oct 2007
    Location
    San Diego, CA
    969
    Rep Power
    47
    Went back to check it out and it is a hard wired connection to the network.
    not sure where to go next with this one.
  6. #6
    Join Date
    Jun 2009
    Location
    /Florida
    552
    Rep Power
    39
    when is the last time that computer has been update. there was a problem a while back that Microsoft update for window 7 broke the scanning capability . they finally did an update to fix problem. what version is window 7 home or office. Check that in folder that your new user name is in both sharing and security tab and have full permission. on copier in address book try adding it again and browse the system to see if it find computer and then browse to folder it should ask for login information then try connection test. might want to see what antivirus software they have on that computer could be different. i know McAfee and Norton have to give it permission to pass through along with others. If allow temporary turn off and see if it goes through.
  7. #7
    Just a tech 250+ Posts keithxxiii's Avatar
    Join Date
    Nov 2014
    464
    Rep Power
    28
    check if the network profile is set to public and also try to browse it from the device.
    Aye! Cut the crap
  8. #8
    Senior Tech 2,500+ Posts
    mikadonovan's Avatar
    Join Date
    May 2008
    Location
    Indianapolis, Indiana
    2,922
    Rep Power
    99
    Usually when I get that there is an issue with the password, or the pathway is incorrect. Folder shared? Firewall disabled? Network discovery on? 802.11 enabled? When creating the scans user profile, did you give it admin rights? SMB1 enabled in windows features?
    NEVER ASSUME ANYTHING
  9. #9
    Join Date
    Oct 2007
    Location
    San Diego, CA
    969
    Rep Power
    47
    Quote Originally Posted by mikadonovan View Post
    Yes to all of the above except I did not give it admin rights.
    i also created the same “scanner” user on the 3 other computers and they all worked fine.
  10. #10
    Join Date
    May 2008
    Location
    2,922
    Rep Power
    99
    Quote Originally Posted by copyaction View Post
    802.11 enabled should be a "no". When creating a separate user profile for scans, I have always had to select "run as administrator" in order to get it to work. BTW, you can have 5 brand new pc's of the same model and 2 out of the 5 will have scanning issues that the others don't. Different builds, I guess. Drives me nuts.
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
