Hi there,
recently I had to service a Ricoh C 3003. After doing all the firmware updates (this was mandatory) I did my usual testing and noticed an issue. I got a big black line on the right side of the page when using the ARDF (normal scanner also).
At first I thought it was some dirt still being somewhere which I might have overseen as I cleaned the machine, so I did it again and even after that the problem still occured.
After spending some more time I found out it's actually a border problem when scanning/using ardf. That means the page is shifted slightly to the left side and thus there's this black border on the right side. As workaround I set the borders in the normal user menu and programmed it as default, but this only works for copying/scanning. For example when sending a fax it still occours, also it has to be always selected in the job settings. Sometimes they click around and the option is then disabled. Normal printing from PC however is fine.
Ricoh told me to check SP 1 001 (...), 002 (...) 103 (...) and 4 -008, 010 and 011, also 6-006 (...), and if it doens't work I should consider reseting.
Since it's a long drive I really want to make sure I'll be able to fix it when I go there. Do you have any other idea regarding this issue?
Thanks a lot.
Best regards,
Trommel
Bookmarks
