Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: Aficio 2022
  1. #1
    Field Supervisor 500+ Posts
    Join Date
    Aug 2015
    Location
    Alexandroupolis, evros
    593
    Rep Power
    0
    Aficio 2022
    When paper is at vertical (A4R) position , it prints with out problem . When paper A4 is horizontal position or using A3 paper we have paper jam . paper stops just before the exit. Paper cassete is set up cerrectly. Cleared all rollers , no obstacle in paper path, replaced exit sensors.
    Also when making double sided copies had no problem.
    Noticed that using paper that have made a little earlyier copies it works ok!
    Any idea where the problem is?
  2. #2
    Service Manager 1,000+ Posts luca72's Avatar
    Join Date
    Oct 2017
    Location
    Milano, Italia
    1,375
    Rep Power
    69
    Re: Aficio 2022
    Quote Originally Posted by Gab View Post
    hi, what does say "plotter jam history" ?
  3. #3
    Retired 10,000+ Posts
    Aficio 2022
    slimslob's Avatar
    Join Date
    May 2013
    Location
    Bakersfield, CA
    34,242
    Rep Power
    992
    Re: Aficio 2022
    Lead edge stops just before the exit is very common symptom of a trail edge jam at the registration roller, trail edge detect is either too early or too late. Usually means that the actual paper length does not match what the tray is set for. With that old a machine the size switch could be bad. Check the paper size and orientation shown on the display panel exactly matches the paper in the tray.
  4. #4
    Geek Extraordinaire 2,500+ Posts KenB's Avatar
    Join Date
    Dec 2007
    Location
    Cleveland, Ohio
    3,950
    Rep Power
    126
    Re: Aficio 2022
    With the machine being older than dirt, I would be highly suspect of any rubber or rubber-like feed roller or shaft, as I'm sure they have all deteriorated to a point where they can't feed reliably.
    If not done already, I think I would start there.
  5. #5
    Senior Tech 100+ Posts semi's Avatar
    Join Date
    Sep 2008
    Location
    UK
    187
    Rep Power
    34
    Re: Aficio 2022
    Pressure roller,had this many times out in the field-back in the day-might be time for a upgrade
  6. #6
    Join Date
    Aug 2015
    Location
    593
    Rep Power
    0
    Re: Aficio 2022
    Quote Originally Posted by slimslob View Post
    I have checked the papoer size and orientation and it is ok (with this problem paper exits 3-4 cm and stops)
  7. #7
    Service Manager 10,000+ Posts
    Aficio 2022
    Phil B.'s Avatar
    Join Date
    Jul 2016
    Location
    Raleigh NC
    22,792
    Rep Power
    661
    Re: Aficio 2022
    are there parts still available for these dino's?
  8. #8
    Aficio 2022
    slimslob's Avatar
    Join Date
    May 2013
    Location
    Bakersfield, CA
    34,242
    Rep Power
    992
    Re: Aficio 2022
    Then what is the jam code? That will tell us exactly which sensor and whether it is a 'late' jam, lead edge, or 'lag' jam, trail edge. I mean the numeric jam code not the letter location code. You may also want to look at SC 5707 Plotter Jam History as it will also show you what size the 2022 thinks was running through.
    And in your original post you said the paper was stopping before the exit but now it has moved to 3-4 cm past the exit, which is it?
  9. #9
    Join Date
    Aug 2015
    Location
    593
    Rep Power
    0
    Re: Aficio 2022
    I said just before the exit . Actuallly it looks like it stops little earlier and till rollers stops it reaches just the before exit. Later i said i know the problem when someone has different paper in cassete and he has,t set up coerrect the cassete . At this case it stops 3-4 cm after the exit. It is not the same with this case.
    Also i am wondering why it works fine at duplex copies also when i use paper that i have used just before to make copies it works fine almost in all copies.
  10. #10
    Service Manager 1,000+ Posts Gift's Avatar
    Join Date
    Mar 2011
    Location
    Gothenburg
    2,332
    Rep Power
    86
    Re: Aficio 2022
    Quote Originally Posted by semi View Post
    You're right and not bad - I never would have recalled that
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
