Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Ricoh MP C305
  1. #1
    Senior Tech 100+ Posts
    Ricoh MP C305
    Join Date
    Aug 2016
    Location
    Durango, CO
    102
    Rep Power
    22
    Ricoh MP C305
    Has anyone had any problems printing from Dentrix software? My customer is having problems not wanting to print duplexed prints. Everything, (settings) seem to have the duplex turned off.
  2. #2
    Service Manager 5,000+ Posts
    Ricoh MP C305
    copier tech's Avatar
    Join Date
    Jan 2014
    Location
    London
    7,560
    Rep Power
    182
    Re: Ricoh MP C305
    Quote Originally Posted by thurmmy View Post
    What have you tried so far?
    • Update the firmware (all modules)
    • Update the driver or try another PCL 6 recommended.
  3. #3
    Ricoh MP C305
    Join Date
    Aug 2016
    Location
    Durango, CO
    102
    Rep Power
    22
    Re: Ricoh MP C305
    The firmware is all up to date and I had their IT person change drivers. I have not heard back from them yet. We did send the dentrix documents to another printer, MP C300, and that did go thru without a problem. We then changed the driver to the same as that. We shall see what happens and I will let you all know the results. Thank you.
  4. #4
    Retired 10,000+ Posts
    Ricoh MP C305
    slimslob's Avatar
    Join Date
    May 2013
    Location
    Bakersfield, CA
    34,238
    Rep Power
    992
    Re: Ricoh MP C305
    Quick question, is it that the customer wants to print duplex and the C305 won't do so? If that is the then it is in user tools. Duplex printing is turned off for all trays or at least the tray they want to use. Change the setting for "Apply 2-sided" in [System Settings] to enable duplex printing for the paper tray. For details
    about setting "Apply 2-sided", see "Tray Paper Settings", Connecting the Machine/ System Settings
  5. #5
    Ricoh MP C305
    Join Date
    Aug 2016
    Location
    Durango, CO
    102
    Rep Power
    22
    Re: Ricoh MP C305
    No Slimslb, actually it is the opposite. Dentrix wants to duplex and even though all my setting are set to duplex off it still wants to duplex. The devise goes into error and I have to go to printer select tray 1, the only one, then press form feed and then it asks if you really want to cancel duplex mode. I may hve those steps wrong a bit but that is the jist of it.
  6. #6
    Ricoh MP C305
    slimslob's Avatar
    Join Date
    May 2013
    Location
    Bakersfield, CA
    34,238
    Rep Power
    992
    Re: Ricoh MP C305
    So the customer does not want duplex but the Dentrix software keeps trying to duplex. That sounds like it is in Dentrix's court. Time to have the customer schedule a support call with Dentrix at time when you can be there to talk to them. Or the real problem that the customer does not have support contract with Dentrix?
    Maybe the customer might be better off with a different software. My dentist has used Patterson Eaglesoft. It does appears to do everything that Dentrix can do. It also interfaces with VOIP phone systems allowing each workstation computer to be associated with a specific extension so that patients can be dialed by the software and when incoming patient calls are answered the called ID takes the person answering directly to the patient or patient family associated with that number. It is a client-server based system and they have specific hardware and OS requirements but work with any printer. https://www.pattersondental.com/cp/S...are/Eaglesoft#
  7. #7
    Service Manager 1,000+ Posts Gift's Avatar
    Join Date
    Mar 2011
    Location
    Gothenburg
    2,332
    Rep Power
    86
    Re: Ricoh MP C305
    I agree, customer can try and forbid 2-sided copy/print via user tools - but that's just a quick&dirty workaround attempt, everything else is not part of our end. Many applications can override driver settings, like MS office likes to mess around with tray settings.
  8. #8
    Ricoh MP C305
    Join Date
    Aug 2016
    Location
    Durango, CO
    102
    Rep Power
    22
    Re: Ricoh MP C305
    Still not resolved.
  9. #9
    The Wolf 2,500+ Posts mojorolla's Avatar
    Join Date
    Jan 2010
    Location
    Cleveland OH
    2,513
    Rep Power
    126
    Re: Ricoh MP C305
    In Dentrix.... File, Setup Printer or something like that.
    You have to not only set the default printers for the software but also the defaults for the modules within the software. Labels print to label printer, prescription to Rx printer, etc...
    We have a pediatric dentist at the end of our street we manage IT and copiers for who use Dentrix software
  10. #10
    Geek Extraordinaire 2,500+ Posts KenB's Avatar
    Join Date
    Dec 2007
    Location
    Cleveland, Ohio
    3,950
    Rep Power
    126
    Re: Ricoh MP C305
    If you’re feeling particularly geeky, perform a card save. You’ll need an SD card and to flip a few 0s to 1s in Printer SP, but it’s easy to do.
    Send a job, and open the file on your PC.
    You will quickly see if duplex is enabled by examining the output.
    But I agree with Motorola, it really sounds like he has a handle on it, and the setting is in the app.
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
