Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Senior Tech 100+ Posts
    Join Date
    May 2020
    Location
    Lagos
    226
    Rep Power
    11
    Toner Density Ricoh 2503
    Hi All,
    Is there any sp adjustment to reduce black toner density on Ricoh mpc2503 or any sp to reduce VT on OPC??
    Thanks.
  2. #2
    Service Manager 1,000+ Posts
    Join Date
    Oct 2011
    Location
    Hunter Valley, NSW
    1,020
    Rep Power
    57
    Re: Toner Density Ricoh 2503
    Follow PM schedule and use genuine parts.
  3. #3
    Join Date
    Jul 2015
    178
    Rep Power
    21
    I have seen after market toner cause problems on this model......
  4. #4
    Join Date
    May 2020
    Location
    Lagos
    226
    Rep Power
    11
    It's an OEM toner. I still don't know why the black density its too dark.
  5. #5
    Join Date
    May 2020
    Location
    Lagos
    226
    Rep Power
    11
    All parts are genuine OEM parts. I know there's an sp settings to be done, but I've forgotten. I'll try to remember.
  6. #6
    Join Date
    Oct 2011
    Location
    Hunter Valley, NSW
    1,020
    Rep Power
    57
    Quote Originally Posted by Pixtech Frameworks View Post
    It’s in the service manual, initialisation after replacing dev.
  7. #7
    Retired 10,000+ Posts
    slimslob's Avatar
    Join Date
    May 2013
    Location
    Bakersfield, CA
    34,242
    Rep Power
    992
    The problem is you do not think the problem all the way through. Any SP change you make to reduce, or increase, the density of the K toner will result in less toner being put on the drum. Less toner on the drum will result in less toner on the ITB. That will result in the ID patch being lighter, or darker, and Process Control will reverse your adjustment.
  8. #8
    Join Date
    May 2020
    Location
    Lagos
    226
    Rep Power
    11
    I remembered I countered same situation and there's and sp 3xxx, but can't remember anymore.
  9. #9
    slimslob's Avatar
    Join Date
    May 2013
    Location
    Bakersfield, CA
    34,242
    Rep Power
    992
    At least one of the critical SP settings that I used to change in previous models does not exist on the MP CXX03 series.
  10. #10
    Service Manager 5,000+ Posts
    copier tech's Avatar
    Join Date
    Jan 2014
    Location
    London
    7,561
    Rep Power
    182
    Hi All,
    Thanks.
    Carry out a PM replace the K PCU & Dev if over life.
    Update the firmware & run ACC.
    This will most likely resolve any print quality issues you have.
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
