Page 1 of 4 1234 LastLast
Results 1 to 10 of 36
  1. #1
    Senior Tech 250+ Posts
    Join Date
    Oct 2019
    Location
    Kzn
    319
    Rep Power
    20
    Screwdriver of choice - Ricoh
    Not to sure if this is the right section for this but...
    For Ricoh machines what is your recommended screwdriver of choice?
    I'm currently using a CK Philips 2 x 250mm shaft, overall length is 350mm. Using this for more than 15 years. It's a good screwdriver but it cams out alot. I read that JIS might be better.
    Thank you in advance
  2. #2
    Service Manager 1,000+ Posts
    copiertec's Avatar
    Join Date
    Jan 2016
    Location
    Centereach, L.I. New York
    2,161
    Rep Power
    101
    Re: Screwdriver of choice - Ricoh
    The best way to tell if the screw is JIS type is to look for a small round indentation on the head, if they do have the indent, your best bet is to use a JIS screwdriver otherwise it can strip the screws.
    Phillips Bits Vs. JIS Bits: What's the difference?
  3. #3
    Retired 10,000+ Posts
    slimslob's Avatar
    Join Date
    May 2013
    Location
    Bakersfield, CA
    34,213
    Rep Power
    991
    I satarted using a Craftsman #2 Phillips with 12 inch blade over 20 years ago when the Apeco Bond Copier, relabeled Royal RBC1, first came out. It could loosen the cover screws without having to use an impact driver. You could actually see the torque build up in the length of the blade until the screws popped loose. Also back then Craftsman had a lifetime guarantee on their tools. If a tip became worn to where it did not hold to the screws properly, just take it to the nearest Sears or Orchard Supply and they would replace it free.
  4. #4
    Join Date
    Nov 2007
    Location
    New Jersey
    1,670
    Rep Power
    87
    Quote Originally Posted by slimslob View Post
    That old Royal was a good machine.
    I use this Vessel No.220 Ball-Grip Screwdriver (JIS) (+2)x200 300mm Long
    $14.00 US at Amazon.
  5. #5
    slimslob's Avatar
    Join Date
    May 2013
    Location
    Bakersfield, CA
    34,213
    Rep Power
    991
    Quote Originally Posted by anothertech View Post
    Great plastic pop right after maintenance.
  6. #6
    Copier Technician 1,000+ Posts
    mga's Avatar
    Join Date
    Dec 2010
    Location
    london
    1,393
    Rep Power
    135
    Quote Originally Posted by KeviM View Post
    I've used for years and think the best
    Snap on ratchet long and short shafts and 5.5mm magnetic nut driver
    Regards Mark
  7. #7
    slimslob's Avatar
    Join Date
    May 2013
    Location
    Bakersfield, CA
    34,213
    Rep Power
    991
    One thing about Ricoh, they always have a lot of hex head screws that tend to fall off even a magnetized #2 Phillips. Therefore a magnetized 5.5mm nut driver is a must.
    Hex Nut Driver Strong Magnetic Head Hollow Shaft Lengthened Sleeve Screwdriver Red Plastic Handle Bit Holding Screwdriver(5.5mm) - - Amazon.com
  8. #8
    Service Manager 5,000+ Posts tsbservice's Avatar
    Join Date
    May 2007
    7,135
    Rep Power
    346
    Vessel is Japanese company and I'm about to purchase their screwdriver(to replace my Wera) from some time. Thanks for heads up.
    I don't reply to private messages from end users.
  9. #9
    Join Date
    Oct 2019
    Location
    Kzn
    319
    Rep Power
    20
    Quote Originally Posted by tsbservice View Post
    How was your wera screwdriver? I hear that it's 1 of the better screwdrivers out there but I'm not sure how good it is for photocopier technical repairs
  10. #10
    Join Date
    Oct 2019
    Location
    Kzn
    319
    Rep Power
    20
    Looking for these... Unfortunately vessel only just entered the South African market and they only have short and standard length screwdrivers available. Upto 150mm in length which is a bit short for me
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
