Results 1 to 7 of 7
  1. #1
    Join Date
    Nov 2019
    Location
    Ankara
    1
    Rep Power
    0
    Question Ricoh Aficio MP C2551AD Network Scan To Folder
    I use the RICOH Aficio MP C2551AD as a network printer at work. The device scans to the public folder on the network. But I wanted to use local network instead of public network. Device configuration for this purpose; Instead of the FTP protocol, which is a common network folder, I set it up to scan to the shared folder I created on the client computer with the Windows 10 operating system and the 1809 architecture included with the SMB protocol. . I never made it. I checked the network connection, the printer, and all settings on the client computer. Everything looks normal.
    The configuration settings are as follows;
    Registration Number: 00002
    Key Picture: file name
    Title
    Title 1: None
    Title 2: None
    Title 3: None
    Add to Favorites: Open
    Authentication Information
    User Code: Empty
    SMTP Authentication: Do Not Specify
    Folder Authentication: Specify Another Authentication Information Below:
    Login Username: xxxxxx (I'm sure I typed it correctly)
    Login Password: xxxxxx (I'm sure I typed it correctly)
    LDAP Authentication: Do Not Specify
    Available Functions
    Color Copy Mode Limitation: Limit Automatic Color Selection (Selected by default)
    Protection
    Use Name As: Destination (Selected by default)
    Protect Goal
    Protection element: Empty
    Protection Mode: Idle (Inactive)
    Email
    Email Address: Empty
    User Certificate Status: None
    User Certificate: Empty
    Encryption: Personalized setting (Selected by default)
    Folder
    Protocol: SMB
    Port # 21 (Written by default, inactive, cannot be changed)
    Connection Type: NDS (selected by default, inactive, cannot be changed)
    Server Name: Empty (Inactive, cannot be changed)
    Path: \\ xxx.xxx.xxx.xxx \ filename (I'm sure I typed it correctly)
    Add to group
    Group Details: Change (Enabled, not using)
  2. #2
    Retired 10,000+ Posts
    slimslob's Avatar
    Join Date
    May 2013
    Location
    Bakersfield, CA
    34,242
    Rep Power
    992
    Re: Ricoh Aficio MP C2551AD Network Scan To Folder
    Have you checked to see if the C2551 has to proper firmware to support SMB v2/3, assuming it is available. It is necessary for SMB scan to folder on Windows 10. I have also found that SMB works best if you are using NetBIOS name and not IP address especially if you are on a domain. The OS security assumes that files arriving via SMB and sent directly to an IP address to be malicious content from outside the domain.
  3. #3
    Service Manager 5,000+ Posts
    copier tech's Avatar
    Join Date
    Jan 2014
    Location
    London
    7,561
    Rep Power
    182
    Quote Originally Posted by slimslob View Post
    I agree as slim says I still have a few of these old models about & have needed to update the firmware on a few for users that insist on scanning via SMB.
    Usually happens after customer updates to Win 10 or even a routine Windows update.
  4. #4
    Field Supervisor 500+ Posts
    dalewb74's Avatar
    Join Date
    Feb 2018
    906
    Rep Power
    30
    have you checked under the network advanced sharing permissions are all set correctly? i have seen a windows update turn off something that needs to be on. looks like for the path you used the IP, have you tried it with the PC name?
  5. #5
    Ricoh Fanboy 1,000+ Posts Oze's Avatar
    Join Date
    Jul 2008
    Location
    Toowoomba,QLD
    1,662
    Rep Power
    64
    I'm adding a third voice to updating the firmware to add SMB v.2.0/3.0 support.
    It looks as though the latest firmware will do this (I just checked the version numbers).
  6. #6
    slimslob's Avatar
    Join Date
    May 2013
    Location
    Bakersfield, CA
    34,242
    Rep Power
    992
    Quote Originally Posted by dalewb74 View Post
    Microsoft updates turn off SMBv1 support. You can turn it back on but the next update will turn it off again.
  7. #7
    Service Manager 1,000+ Posts
    GIUBOSS's Avatar
    Join Date
    Jul 2013
    Location
    Rome, IT
    1,298
    Rep Power
    68
    momentarily disables the firewall and then also the antivirus. Check if it works and if it changes the authorizations inside them
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
