Good evening everyone.
Got this 1052 with a problem in the exit tray of the FS-532.
Long story short it messes up the sets,tried to remove the output alignment mechanism(the 2 little plastic arms that stack the paper when it comes out),
tried to disable the upper gripper mechanism,tried to adjust the exit tray by making it go a little bit up or down from its default position,tried to play with paper weights..nothing helps
Here is a photo of the end result
The photo is kinda bad because you cant clearly see what happened at the top but the first sets are fine but when it starts to stack up the paper starts to do this weird curve and eventually the arms are hitting the paper oneside/left or right/ and it messes up badly.
Has anyone came across this?Il have a video soon on its behaviour when disabling the output alignment hands which makes things even worse from the first set.
