Here you go
Solution ID
TAUS0703482EN* Solution Usage 17
Description
C-2211 (C2211), C-2212(C2212), C-2213 (C2213) or C-2214 (C2214)usually when the machine is running in thick paper mode (1/2 line speed).
77
Copyright 2008, Konica Minolta Business Solutions U.S.A., Inc. July 2008
bizhub PRO C6500 Warm-up, wrong display, incorrect operation, lock-up
Solution
PROBABLE CAUSES:
1. Incorrect drum speed.
Please install attached version 30-GCA firmware (bizhub PRO C6500) or attached version 12-GCA (bizhub PRO C5500) to correct the drum speed.
After installing the firmware please set the following DipSW to the recommended setting:
DipSW21
bit 6 bit 7
0 0 Default
1 0 0.1% up
0 1 0.2% up (Recommended)
1 1 0.3% up
If the symptom recurs with the recommended value, try the 0.3% UP setting.
2. Cleaning blade has "flipped" ona corresponding color.
Replace the respective drum cartridge.To prevent the recurrence of the blade flipping, be sure to apply setting powder onto the surface of the drum.
3. Incorrect Belt Line Speed Adjustment setting.
Check the settingby referring to section10.3.8 Belt Line Speed Adj. (Printer Adjustment) in the Service Manual.If the setting value is not in the range between
-5 to -35, readjust the value within -5 to -35.If -5 to -35 cannot give the satisfactory result, also perform the section 10.3.3. FD Mag. Adjustment (Printer
Adjustment).
Notes :
a. These are drum drive error codes; ensure that the problem is not drive-related.
b.The latest version firmwareis also available via the Konica Minolta Download Selector. Access the Selector from SSD Web Support (CS Expert Support)
by clicking on 'Download MSDS, Drivers, Firmware and more'.
SPECIAL NOTE : Solution contribution by Clinton Marquardt, ESS/SSD and Cesar Jimenez, Production Print/SSD
