Results 1 to 10 of 11
    Trusted Tech 50+ Posts
    Apr 2014
    77
    22
    Konica minolta bizhub C360 constantly reboots when lan cable connected....
    Hi!! I have an Konica minolta bizhub C360, the machine constantly reboots when lan cable is connected, if i disconnect cable, the machine works perfectly, but when reconnect cable, the screen turns off, and the machine reboot... any advice? Thanks.
    Sep 2008
    Flat Rock Michigan
    1,048
    49
    Re: Konica minolta bizhub C360 constantly reboots when lan cable connected....
    Quote Originally Posted by menosmola View Post
    try hooking it to a laptop, or even a switch that has nothing else on it.
    Apr 2014
    77
    22
    Quote Originally Posted by Albonline View Post
    I have tried different lan cable, and tried to connect to a switch, but the problem persist...
    I forgot to say, no error codes displayed on machine...
    guitar9199's Avatar
    Sep 2016
    Eveleth, MN
    1,090
    41
    Almost sounds like you've got a "Power Over Ethernet" issue going on. See if the client uses that, and if they can disable it for the copier's ethernet port.
    Apr 2014
    77
    22
    Quote Originally Posted by guitar9199 View Post
    So, you think thatīs something like "wake on lan"? i will be back tomorrow and try to connect a laptop using a cross cable...
    Senior Tech 100+ Posts toshibadale's Avatar
    Apr 2007
    Jackson, Tennessee
    117
    36
    Someone has a job stuck in the print que. You will have to have everyone check their que. It will not be listed in the job history on the C360.
    Apr 2014
    77
    22
    Quote Originally Posted by toshibadale View Post
    I had thought about it, but too much users have access to this printer, and today had little time... tomorrow more.
    Thanks for advices. I'll tell you later if it has been possible to solve...
    Sep 2008
    Flat Rock Michigan
    1,048
    49
    If he hooked it to a switch, standing alone, there cant be a print job causing this. if he did hook it to a switch standing alone and the problem persists its the mfp board itself , could try the nic reset tool,but when it refuses to talk . haven't seen the reset help.
    Apr 2014
    77
    22
    Any nic reset tool in service mode? canīt remember now, i canīt access pagescope, machine reboot when connect to lan...
    Step aside, noob 1,000+ Posts EarthKmTech's Avatar
    May 2009
    Gigety
    2,142
    75
    Make sure the firmware is the latest, any print job containing illegal characters or even too many in the URL or file name will reboot the machine with early firmware.
    seen this a thousand times even early e series firmware had this bug and usually occurred when printing from web pages etc. Couple years ago i had it twice in 1 day at 2 different sites and both were cake recipes printed off the net.
