Results 1 to 6 of 6
    Jan 2014
    Worcs
    17
    21
    Konica c258 banner printing problem
    Hi
    we have a c258 with an internal stapler brand new that when you print banners 1200 x 297 is smudging the last third of the sheet
    Does anyone know the solution to this
    Firmware is latest
    Certified Konica Expert 2,500+ Posts
    Synthohol's Avatar
    Mar 2016
    North Jersey
    4,988
    217
    Re: Konica c258 banner printing problem
    Is the thickness set correctly?
    Thick 1 and up print slower so less chance of smearing.
    Jan 2014
    Worcs
    17
    21
    Quote Originally Posted by Synthohol View Post
    Hi
    it is set to thick 1 but can i set it too thick 2 ?
    how else can i slow it down as it looks like the paper slightly buckles as it leaves the fuser
    in the old days we called it tail edge flick
    22,471
    How heavy is the media? =^..^=
    habik's Avatar
    2,015
    59
    Try playing with the fuser loop. Or slow it down as mentioned in previous post.
    We had different issue however, so in case you or someone is experiencing halftones being not filled properly a.e. peeling off (white spots) then try to increase the temp by 10'C to start with until you get good result. The fuser can't keep up. It usually happens on the last 1/3 of banner and 1/4 from edges. So smudging or peeling is visible, but not always.
    Jan 2014
    Worcs
    17
    21
    Quote Originally Posted by habik View Post
    Hi
    how do we adjust the user temperature?
