Results 1 to 10 of 12
    Jun 2016
    Bucharest
    9
    Bizhub 421-500 install drum and developer unit
    Hello need help
    I install new drum unit and new developer unit on an Minolta Bizhub 421. I run in service mode TCR Adjustment the copier work fine but after 4 day cylinder was broken. I enter in service mode and i enter in service mode at "part counter" and i noticed the developer and drum is with this "--------------" I attach a pictures to see.What is the correct procedure to setup the drum unit and developer unit to install ???? I run only TCR Adjustment , I need to take another step ????
    Thank You .
    Certified Konica Expert 2,500+ Posts
    Synthohol's Avatar
    Mar 2016
    North Jersey
    4,988
    217
    Re: Bizhub 421-500 install drum and developer unit
    drum and developer are supplies not parts, that may be why there is no # listed.
    RTFM!! 5,000+ Posts allan's Avatar
    Centurion
    5,397
    152
    What kind of damage. post a photo. That machine is working hard if its done 10K+ in 4 days.
    Whatever
    Jun 2016
    Bucharest
    9
    In 10 day the printing volume was 10.500 copies.
    but after i install drum and developer unit i run tcr adjusment , another operation needs to be done ???
    Field Supervisor 500+ Posts Woxner's Avatar
    Jul 2011
    Felixstowe England
    783
    41
    the drum and dev have counters that need to be reset under parts counter before you do the tcr adjustment.
    Jun 2016
    Bucharest
    9
    Can you tell me what is the correct procedure in service mode after i install the drum unit and developer unit in bizhub???
    Service Manager 5,000+ Posts
    copier tech's Avatar
    Jan 2014
    London
    7,559
    182
    Quote Originally Posted by shadows View Post
    The correct procedure is listed in the service manual.
    "Service Mode screen"
    Press [Imaging Process Adjustment].
    2.
    "Process screen"
    Press [TCR Adjustment].
    3.
    "TCR Adjustment screen"
    Press the Start key.
    4.
    Check to see if "OK is displayed, and also check the TCR adjustment data value.
    Note
    • The adjustment is completed in about 180 seconds.
    • When there occurs a TCR adjustment error due to the developer agitating operation not completed
    successfully, the message "operating ..." disappears and an error code is displayed
    Are you rebuilding the drum or replacing complete unit?
    Jun 2016
    Bucharest
    9
    complete replacing with original drum unit and developer unit
    Jan 2014
    London
    7,559
    182
    Your print sample shows lines, the drum is not being cleaned, but this has been replaced.
    Are you using genuine KM toner?
    Jun 2016
    Bucharest
    9
    No , right now in copyer is not oem bizhub toner
