Results 1 to 10 of 11
    Feb 2018
    Newbury
    3
    C35 Not printing Yellow
    Anyone here help me out?
    I have a C35 that isnt printing yellow at all.
    Unit does not have any errors. Everything looks good with the IU/Toner.
    Where should I start first? I cant tell if its in the PU, HVPS, or maybe I have a bad IU.
    Thoughts? Appreciated.
    Jason
    Certified Konica Expert 2,500+ Posts
    Synthohol's Avatar
    Mar 2016
    North Jersey
    4,990
    217
    Re: C35 Not printing Yellow
    i would start with an IU. then the belt unit.
    Also don't ask me for files without a contributor badge.
    Field Supervisor 500+ Posts
    Dec 2009
    682
    60
    After IU check contacts from IU to HV board.
    What is IU life anyway?
    RTFM!! 5,000+ Posts allan's Avatar
    Centurion
    5,400
    153
    Had this before.
    Broken part inside the transfer belt unit. The levers that puts pressure on the yellow transfer roller.
    But sometimes will give a half print if one side is broken.
    I have fixed it with glue before but not worth the time.
    Just lift the belt and have a peek compare the yellow with the rest.
    Whatever
    Service Manager 10,000+ Posts
    Phil B.'s Avatar
    Jul 2016
    Raleigh NC
    22,792
    661
    Quote Originally Posted by jpotts View Post
    Jason
    why do newbie techs ALWAYS look to boards first....
    much like you car .. it will be better to diagnose the issue than heading straight to $$$$$ parts.
    have you checked in SM the operation of parts?
    are the supply lines clogged?
    K.I.S.S.
    Feb 2018
    Newbury
    3
    Quote Originally Posted by Phil B. View Post
    Because when I was going through it I found a broken trace because the PCB was cracked at the screw mount.
    I fixed it.
    Yep. surprisingly the SM for the C35 gives you more about issues with the scanner and fax machine than anything else.
    Its pretty weak at best. not really helpful when most of the flowchart concludes with "replace printer"
    All clear
    K.I.S.S.
    Thanks for the pro tips and assistance
    Feb 2018
    Newbury
    3
    Quote Originally Posted by Toxic View Post
    62% on the Yellow.
    Phil B.'s Avatar
    Jul 2016
    Raleigh NC
    22,792
    661
    Well.
    Good catch on the broken trace..sorry if I knew that wouldn't have queried.
    Glad to see some still can diag/repair such..
    Phil B.'s Avatar
    Jul 2016
    Raleigh NC
    22,792
    661
    So did the repaired trace fix the prob.. or are you still stuck?
    Nov 2010
    melbourne
    41
    29
    Last time I had an issue with one of those machines not printing a single colour, it was the drive coupling on the back wall which is spring loaded, it was stuck in and not engaging the IU drive.
