Results 1 to 6 of 6
    mckenna
    Guest
    Bizhub C353 giving streaky prints
    What is wrong?????? Please help!!
    It seems to do fine with 20lb paper but this is 110 lb card stock. I have done hundreds of these prints with no problems and all of a sudden this is all I can get with the heavier paper
    Senior Tech 100+ Posts
    orestesp's Avatar
    Sep 2019
    Athens
    211
    13
    Re: Bizhub C353 giving streaky prints
    It looks like the toner isn't getting fused to the paper properly.
    Have you set the tray to the correct paper setting?
    Service Manager 2,500+ Posts
    Sep 2005
    South Jersey
    3,861
    135
    Yep. Looks like you don't have the tray set to thick paper. You should run thick paper from side tray ONLY set to thick 3 or 4 paper. If the paper is really glossy it will not work with this model.
    Mar 2013
    Meridian, MS
    1,152
    50
    Quote Originally Posted by mckenna View Post
    There is *some* fuser offset there, but it ALSO looks like it could be the Intermediate image transfer belt cleaning blade going bad as ALL COLORS are being affected!!!Bizhub C353 giving streaky prints
    PS--The "Repetitive Defect" distance is too great which indicates that it IS NOT the fuser rollers...most likely the ITB!
    Sent from my SM-N950U1 using Tapatalk
    REACH FOR THE STARS!!!
    Konica Minolta Planetariums!
    22,476
    464
    Yes, there's a high voltage loss going on here. It could be any one of the imaging units. =^..^=
    mearmi's Avatar
    Oct 2010
    340
    31
    Please check all the imaging units. Remove and check one by one, all are rotating normally and ITB.
