Results 1 to 8 of 8
Thread: XM3150
    Senior Tech 100+ Posts
    Nov 2015
    archdale,nc
    172
    20
    XM3150
    When you try to copy a document either off the glass or from the document feeder the only thing displayed is “scanning” and the only way to get rid of it is to turn off then on. The firmware is current. It will print internal reports but that’s it. They only use it as a stand alone copier.
    Bad flatbed ?
    Thanks,
    Dave
    Service Manager 10,000+ Posts
    XM3150
    BillyCarpenter's Avatar
    Aug 2020
    Long Beach, Mississippi
    13,454
    449
    Re: XM3150
    Quote Originally Posted by deputydogg View Post
    Bad flatbed ?
    Thanks,
    Dave
    Just to be clear:
    1. Can you print from a PC? (Try printing from your laptop)
    2. When you make a copy from the glass, does the mirror move and return to home position?
    Nov 2015
    archdale,nc
    172
    20
    Re: XM3150
    Quote Originally Posted by BillyCarpenter View Post
    Just to be clear:
    Yes I can print the it. The scan lamp never comes on nor does it move.
    Thanks
    XM3150
    Aug 2020
    13,454
    449
    Re: XM3150
    Thanks
    It's odd that it doesn't throw up an error code and it just says "scanning" on the display. Sounds like a board problem.
    Service Manager 5,000+ Posts tsbservice's Avatar
    May 2007
    7,151
    346
    Re: XM3150
    Start with finding a manual and go from there unless someone here isn't having this problem.
    I don't reply to private messages from end users.
    XM3150
    22,471
    Re: XM3150
    Did you print the error log? Codes can be recorded that never show on the display. =^..^=
    May 2019
    Forest Hill, Victoria
    5
    Re: XM3150
    Bad flatbed ?
    Thanks,
    Dave
    Hi deputydogg,
    There is a Lexmark service bulletin in their support website, please refer to the Document ID:TE676
    basically try the following and see how you go:
    1. Backup all their settings first
    2. Perform NVRAM reset
    3. Go Configuration menu > Factory reset > Restore base
    4. Go Configuration menu again > Wipe all settings
    5. Go Configuration menu again > Format fax storage
    6. Go Configuration menu again > Disable LES applications
    If there is HDD install on the device, you might want to Erase all information on disk option in Config menu...again..
    hope all these help.
    Document ID:TE676
    Trusted Tech 50+ Posts trc's Avatar
    Jan 2007
    94
    36
    Re: XM3150
    Sometimes it could be an adf sensor, check them!!!
