Results 1 to 3 of 3
    Mar 2021
    tan
    1
    Ricoh mpc2003 error code 370-02
    Hi,
    Help me to solve this Error code 370-02 in RICOH MP C2003
    Service Manager 5,000+ Posts
    copier tech's Avatar
    Jan 2014
    London
    7,552
    182
    Re: Ricoh mpc2003 error code 370-02
    Quote Originally Posted by Mwammb View Post
    Hi,
    • Description:TM (ID) sensor calibration error (R) Regular reflection optical output voltage of the Front or Center or Rear TM (ID) sensor: Vsg_reg cannot be adjusted to within target range. Upper limit (SP3-320-013: initial value 4.5V) Lower limit (SP3-320-014: initial value 3.5V)
    • Causes:• TM (ID) sensor connector missing/ connection fault • TM (ID) sensor detection window dirt • TM (ID) sensor malfunction • Undulation in the ITB, or belt slippage
    • Code: SC370-03
    • Remedy:• Update the firmware. Remove image transfer unit, and check for TM (ID) sensor connector missing. If it is missing, reconnect it. • Check for dirt on the ID sensor detection window. If te detection window is dirty, clean by predetermined method (do not wipe dry). • Check the condition of the ITB. If undulation or belt slippage has occurred, re-install or replace the ITB. • If neither of the above have occurred, perform TM (ID) sensor replacement
    Copier Technician 1,000+ Posts
    mga's Avatar
    Dec 2010
    london
    1,393
    135
    Hi,
    Clean all id sensors
    Regards Mark
    FOR TRADE AND END USER SERVICE CALLS PLEASE VISIT WEB SITE FOR CONTACT DETAILS. COVERING GREATER LONDON {UK} AND ALL SURROUNDING COUNTIES.
    RICOH, CANON, KYOCERA, KONICA, SHARP, HP/SAMSUNG BROTHER, LEXMARK.
    https://copierservices.simdif.com
