Hello,
Due to global supply issue, TN413 are out of stock, only have TN613 toner at warehouse.
They would be used on C452 copier? Thank you.
Hello,
as far as I can remember they both use the same developer, so I guess the toner must be compatible, I think you just need to change the end cap
Tip for the day; Treat every problem as your dog would.....If you cant eat it or f*ck it....then p*ss on it & walk away...
Yes, for sure. Just swap the caps of break the fins on the 613 cap. You'll need a chip, or if you swap caps it will just read low but won't stop the machine. You can also use 711, 712, 618, 713 although it's a bit more involved because you have to swap the rear indexer, since the 711, 618, 712, 713 are all different
