Hi there,
Im purchasing a new copies/scanner but would like to know which one is better Ricoh 2550 or Kyocera 3060?
Thanks!
Hi there,
Thanks!
In the end, Ricoh is the winner.
VectorLinux---Check it out!
well... in my opinion, the RICOH is the one to go with cause the customer rarely has to see a service tech other than when a PM is necc... i'm a technician that works on both machine brands and i have always reverted back to the ricoh's. you constantly have to see the kyocera's for lightness issues and jamming, leaking toner, etc... but with the ricoh's you can almost go by a schedule for service, i love them. just take it from a guy who works on both, you'll be much happier with a ricoh, kyocera parts break easily, especially if you have employee's that are kinda hard on the equipment when it jams. they'll break off the TC unit by closing the conveying door too hard, happens all the time...
hope this helps and get back to me if you have anymore questions
cameron webb
Desert Office Solutions
Ricoh.
I love these kinds of threads..."Pepsi vs Coke" (No disrespect intended)
I'll have a Coke, please.
OK...I'll lay off the Happy Pills for the rest of the day.
Relax! This firmware injection won't hurt...but it will take 45 minutes.
I would go with Kyocera. If you want more evidence that Kyocera makes the better product, do a search in the Copier Technical Discussion forum for "Ricoh 2550" and then do one for "Kyocera 3060" and see which machine has more threads. Or just click here:
Copier Technical Discussion - Copytechnet.com
Compare the amount of threads in the Ricoh section to the Kyocera section.
I suppose you could argue that people are posting in the Ricoh section to say what great machines they are, but that is highly doubtful.
I have worked on both lines and any of the mid volume Ricoh boxes are the biggest bunch of toner dusting pigs I have ever seen.
When I went to Kyocera I started working on the Falcon I-II seiries. I vacuumed out at least ten machines before the toner filter changes from white and that was only because I had to vac up a toner spill from a customer. Mostly paper dust in these.
Plus they don't have the idiotic toner recycling insanity that Ricoh uses which cause at least 20 percent of the service calls I responded to. Leading of course to reschedules for some arcane part.
"Some days you get the bear, some days the bear gets you."
Cdr. William Riker
