- 30
Konica 7022 code F4611
I need to figure out what this code means the only thing I got is that is an AGC error could anyone help.
Rick
- 32
Do you get the code during warmup? Check that the white reference strip on the underside of the platen glass is clean and positioned properly.
It could be a bad exposure lamp. Go into 47 mode, output 00 and the lamp should come on if it's good.
If it happens intermittantly during copy runs it could be the A/D ribbon cable, scanner motor or DC power supply.
In my experience, it is the inverter board for the lamp, inv1. Replace that and you should be good.
- 30
Thanks SAR and Strider for your support, i got it working by cleaning the white reference strip under the glass it.
Rick
