Results 1 to 10 of 12
    Major Asshole! 2,500+ Posts
    Bizhub 750 keeps on "Warming Up"
    mrwho's Avatar
    Apr 2009
    Combing the desert!
    4,294
    87
    Can someone give me a hint on what's going on?
    This customer has this 750 which, when turned on in the morning, warms up ok, spits out the first job of the day (whether it is hundreds of pages or just one) and after finishing the job starts to warm up and never stops.
    I've been here the last week and I (thought I had) solved the problem by reflashing the machine with the latest firmware, but today the customer called again, stating that it had begun to do the same thing yesterday.
    I've noticed that the fuser lamps turn on and off regularly, so it seems to me that the temperature control is being done correctly. Is there any other temperature sensor (outside the fusing unit) that can affect this (similar to the 7075 problem when the drum heater wasn't functioning properly giving out the "Warming up" message)?
    Mascan42
    Ibid
    mrwho's Avatar
    Apr 2009
    Combing the desert!
    4,294
    87
    Another thing: When checking out the temperature sensors (using Sensor Check, modes 4-1 to 4-3), I get zero readings from the middle sensor (4-2). What I find odd is that I get no fuser error service call. Can anyone explain this to me?
    Mascan42
    Ibid
    Head Tech 500+ Posts SmellsHot's Avatar
    Dec 2009
    Sault Ste Marie, MI
    512
    36
    Make sure your service codes are on.....
    DIPSW 11-7-1
    Also I would check your drum unit out...could be toner on the tcsb....and machine cannot run it's patch check
    Sep 2008
    Flat Rock Michigan
    1,048
    49
    Quote Originally Posted by SmellsHot View Post
    DIPSW 11-7-1
    this should be the fix.might also be worn developer,poor drum gnd, loss of developer bias.
    Curmudgeon at large 100+ Posts RockETop's Avatar
    Apr 2007
    Colorado
    172
    36
    DIPSW 11-7-1
    Yup!
    mrwho's Avatar
    Apr 2009
    Combing the desert!
    4,294
    87
    Thank you all.
    As for the DipSW 11-7, it applies to Jam codes only (at least from my experience and from what the manual says, I could, of course, be wrong).
    About the Sensor Checks I mentioned before, I'm now at another customer's whose machine is running fine, and the address 4-2 (which, supposedly, refers to the middle sensor) also returns zero here. I'm assuming this is normal and it's either a firmware bug, or the middle sensor isn't used?
    I'm going to test now the fusing unit and the ADU driving board. If everything checks OK (the fuser is running fine so far), I'll go back and check on the drum unit.
    Thanks all for your feedback. I'll report back soon.
    Mascan42
    Ibid
    Trusted Tech 50+ Posts fernan's Avatar
    Jan 2008
    philippines
    61
    34
    Quote Originally Posted by mrwho View Post
    Thank you all.
    i have encounter that keeps on warming up after a couple of copies that's it always warming up
    try to change the TSCB .................. do this first before the fusing unit which is havier than TSCB or the ADU driver bord wich is much bigger than TSCB .......... just try there is no harm on trying ..........
    good luck
    Senior Tech 100+ Posts selig67's Avatar
    May 2008
    Portland, OR
    156
    34
    Solution
    CAUSE: Dirty or failed Toner Control Sensor Board.
    SOLUTION: Check
    Service Call Counter 28-01 (Maximum Density Correction Error 1) for excessive counts. Clean or replace the Toner Control Sensor Board
    (p/n 56AA 9102E).
    ALIEN OVERLORD 2,500+ Posts fixthecopier's Avatar
    Apr 2008
    The Republic of Pineland
    4,716
    134
    I have had the tcsb under the drum will cause that and we had a bizhub 600 that had one of the heater lamps going out. Took 20 minutes to get a copy.
    fuckthesystem
    Guest
    ...you should know this one!
    Caro colega, o meu amigo deveria saber resolver este problema!?! O sensor do tambor está sujo ou danificado ou, tens uma lampada da fusão fundida! Abre os olhos.....pá!
    Translation: "Dear Colleague, you should be able to solve this problem!?! Drum sensor dirty or damaged or, one of the fuser lamps is "broken"! Open your "eyes"....man!"
    De um amigo.
    (From a Friend.)
