Registration is off by 3/4 of a inch, Need to know how to get into tech mode to see if it is adjustable,or if anyone else has a fix, I can get to engine test mode but it does not give many options.
Thanks Jeff
Thanks Jeff
Have you tried cleaning the cassette pickup rollers? Jam timing is so loose on the tabletop Samsungs that the registration vary significantly without pulling a jam. Common on the CLP-300/XAA, registration can be late by as much as 20mm as a result of dirty pickup rollers. As far as I know there isn't a registration adjustment, but maybe the 4200 is different. =^..^=
This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
Paul@justmanuals.com
Not sure if this is the same, but on the SCX6545 holding down 1,2,3 at the same time and then inputting 1934 will get you there. Have you checked the registration sensor? Good luck
