- 0
KM C6501 Print Speed 11x17 w/ PFU and Stacker
Like the title says, i'm wondering if anyone has tested the print speed of a double sided, black print, 11x17 20# bond, with a PFU and Stacker attachments to a KM C6501.
I've found two speed descriptions for the machine, one in the hand book that you get when you buy one, and the speed description in the service manual.
My current run time measured over 30 min seems to be significantly slower than expected, so i was wondering if anyone else has taken measurements, or can tell me where I might be able to find a source to calculate from.
Thank you for your time and help
Copier Demon
- 26
Re: KM C6501 Print Speed 11x17 w/ PFU and Stacker
The print speed will vary due to several factors: temperature, humidity, toner coverage, etc. There are settings on the C6501 that can be set to reduce time between calibration or "stabilizing" cycles.
