BIZHUB C300 copies are slightly out of square
Greetings all, I have a problem on the konica bizhub c300 copies are slightly out of square it seems that the inserted sheet to be copied is not inserted correctly, there may be an adjustment of the scanner?
Re: BIZHUB C300 copies are slightly out of square
Is the same happening on internal prints? If not, grab the left corner of the scanner bed and lift it slighty. That should do it.
Darren
