Hi fellow techs, I replaced a fuser in a cl7200 because it said it was time to replace type c fuser, how do I clear the message ?
New fusing units have a spring that makes a circult.
When the rollers turn for the first time the spring disconnects breaking the circult which tells the machine it a new unit and it resets the PM counter automatically.
Alternatively you can manually reset the fuser PM counter using SP7804-016.
Or you can take plastic top off the fuser and reconnect the spring clip next to the gears.
- Knowledge not shared, is eventually knowledge that becomes lost... like tears in the rain.
Fully qualified technician for Ricoh - Canon - Sharp - HP - Brother
thanks for the reply, however I don't know how to get into the mode to reset the fuser count. I have to service this machine with NO manuals at this time for a customer so any help is GRAITLY apprecheiated.
Reset the spring on the fuser, it does the same thing.
Thanks DaZ, however that did not work. the original fuser did not have a spring at the end. the new fuser does but it is still atattched. I don't know how to enter service mode to manually reset the count. Any ideas.
Yup look it up in the service manual.
