KM-3035 NW-FAX Question/Problem
I have this setup so that faxes are emailed to a single user(fax@xxx) The problem I am having is that the faxes are making it to the RX folder but some are being dropped(best way I can think to describe it) and not being set to fax@xxx. I can retrieve them manually by going to the RX folder but I shouldn't have to and would only do so if someone asks for a fax that did not go to email. I hope this makes sense.
Thanks for any input you could provide.
fax
you have to setup email on copier
smtp information
if its not set email will not work
