Results 1 to 8 of 8
    Technician pager727's Avatar
    Aug 2013
    22
    22
    bizhub 350 adf jam, totally lost
    I have a bizhub 350 with the df-605, it is jamming intermittently, i have replaced the feed tires and sep tire and now at a loss.. any ideas?
    Thanks!
    Aging Tech 10,000+ Posts
    copier addict's Avatar
    Jul 2013
    Diamond
    11,984
    324
    Re: bizhub 350 adf jam, totally lost
    If you could let us know where in the DF the jams are occurring and/or the jam code, that would be very useful in trying to troubleshoot your problem.
    Darren
    Service Manager 5,000+ Posts
    Jan 2006
    Las Vegas, NV
    9,940
    154
    Lightbulb Re: bizhub 350 adf jam, totally lost
    This Parts & Service Manual can now be purchased for $12.77 and downloaded immediately after payment from:
    http://www.justmanuals.com
    paul@justmanuals.com
    Aug 2013
    22
    22
    it happens right before the transport rollers, i believe the one way gear on the transport rollers is slipping
    PHD in Sh!t Disturbing 250+ Posts Shadow's Avatar
    Sep 2011
    Vancouver Island
    455
    34
    you will need to remove the shaft completely and the bearing as well.
    take some emery cloth and lightly scuff cross ways on the shaft to remove the glazing.
    clean the one way bearing with alcohol and the end of the shaft as well.
    reassemble the unit and test operations.
    I can't remember if there are 1 or 2 one way bearings in that particular DF, if there is more than 1, do them all.
    this will help improve the paper feed in this model DF.
    $hit Happens - Deal with it and move on.........................................................................Lock & Load
    Technician rahadyan himura's Avatar
    Jun 2012
    bandar seribegawan
    21
    25
    Quote Originally Posted by pager727 View Post
    Thanks!
    maybe your problem from drive section, you can check (4344 5059 01) TORSION SPRING at rear RADF, i face this problem and found the torsion spring is broken. checking at drive section and you can find your solution.
    i hope this can help you
    rahadyan
    Trusted Tech 50+ Posts
    Dec 2009
    94
    30
    I had a bushing on one of the roller shaft that was worn down. I had to replace bushing and the shaft. Thr Only
    Issue I had with with the 350 adfs.
    ALIEN OVERLORD 2,500+ Posts fixthecopier's Avatar
    Apr 2008
    The Republic of Pineland
    4,716
    134
    There are 2 photocells detecting entry and exit. If they are dusty, it will jam.
