Results 1 to 10 of 18
    Service Manager 5,000+ Posts
    C280 dots all over prints
    copier tech's Avatar
    Jan 2014
    London
    7,561
    182
    I hope someone can help, no idea what causes this. It prints the gradation prints perfecty, all other copies or prints have these dots!
    i've tried updating the firmware.
    I thought the laser but it prints gradation pattens ok.
    Apr 2009
    LaPorte Indiana
    1,054
    43
    Re: C280 dots all over prints
    Has this machine gotten reset , initialized, or a new NVRAM???
    Jan 2014
    London
    7,561
    182
    None of that yet no
    Step aside, noob 1,000+ Posts EarthKmTech's Avatar
    May 2009
    Gigety
    2,142
    75
    MFP board or ram.
    try the ram first, if no go, mfp, problem solved.
    habik's Avatar
    2,015
    59
    Try set it up as if it was new machine.
    Sent from my iDon't believe in marketing device using Tapatalk
    Sep 2014
    Tucson Arizona
    7
    C360 have a nasty habit of their mfp's failing for no reason. I havent had those same dots, but train tracks and other image distortions on a couple and it has always taken a mfp board
    I think the initial setup lines are different than those, i think they are solid bars. but it will display them if its been reset or somtehing. to get rid of those lines you have to run through the initial setup again, doing touch panel adjustment < a couple more things> and ending with the gradation adjustment.
    Jan 2014
    London
    7,561
    182
    Thanks for all the info, I don't feel it's an initial install type fault as the lines look different, I did however go through the setup anyway. I have another c280 I can take an MFP from, i'll try the ram first. If I do fit a used MFP board will I loose all the machine/customers settings, IP, address book etc? If so I guess I can import/export those settings. Also fitting a used MFP board will I get that license management error message!?
    Jul 2009
    notts
    40
    31
    Hi, you can keep the mfp and the nvram together from your other machine to try to diagnose the fault on this machine, you will get licence man error, but this way if the fault is not the mfp you can refit the original without the management error, if you find that the mfp is at fault and fit the mfp from the other machine make sure the firmware level is the same otherwise you will end up having to format the hdd, then you will lose your scan settings, otherwise you should only get the licence management error, which is easily fixed by obtaining a repair code from konicas LMS.
    Jan 2014
    London
    7,561
    182
    If I fit the MFP from my good machine, can I use the NVRAM from the faulty c280, or is it best to keep the NVRAM on the original MFP boards?
    Can I avoid the licence management error? what boards do I swap from my working c280 to my faulty C280, how about counter readings, will they change over? sorry for all the questions but I'm looking for a the quickest & simplest fix!
    May 2009
    Gigety
    2,142
    75
    Quote Originally Posted by copier tech View Post
    Counters, machine settings and hard drive format key are on the nvram among other stuff. it should stay with the machine it came with.
    If you want the easiest fix of all use a brand new mfp board, drop it in, update firmware and away it goes.
