Hi Guys,
When updating the firmware on these machines do I need to use a CF Card? or can i use SD to CF? Whats the maximum size of card the machine will take?
I'm used to updating firmware via usb.
Cheers
Hi Guys,
Cheers
Need a CF card. I have only had success using cards with a capacity of 256mb, or less. Not all cards below 256mb will work, either. Kind of a trial-and-error process to find one that works.
You should use CF card. Did't try SD+adapter. Also not any 128/256 Mb would work! You have to check it out. I tested 4-5 makers to found working one. I think CF card from GA-1200 works (TOSHIBA's network scan option for eSt167).
BR
I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
