have a konica c361 customer says doc feed will work great for months then they will have a day or 2 where it jams time after time and then it runs fine again for a month or 2. i noticed when i was there ir ran good for a while then it started jamming. on 1 sided it would take it about 2 inches out then stop. on double side it would do first side then send it out to far for the tires to pull it back in. if i held my hand there so paper wouldnt come out as far it worked fine. i took plate off that covers exit switch and tires and nothing blocking exit switch, seams to operate fine. it jammed over and over then suddenly worked fine again. any ideas
