Results 1 to 6 of 6
  1. #1
    Master Of The Obvious 10,000+ Posts
    Toshiba Cloud Connect
    blackcat4866's Avatar
    Join Date
    Jul 2007
    Location
    Lapeer, Michigan
    22,445
    Rep Power
    462
    Is anybody doing Toshiba Cloud Connect? Can you give an overview of how this gets set up? =^..^=
  2. #2
    Service Manager 5,000+ Posts
    SalesServiceGuy's Avatar
    Join Date
    Dec 2009
    Location
    Nova Scotia
    7,698
    Rep Power
    223
    Re: Toshiba Cloud Connect
    The procedure my vary via country but basically you have to contact Toshiba Tec National Service Dept and register the Serial #s of e5055C series - eBN2 copiers with them before they will be can be uploaded to the secure Microsoft Azure server on which eCloud Connect(ECC) resides. There may or may not be a minimal fee for each copier registered under this service. Toshiba would really like dealers to sample this great advance in remote copier service capabilities which can include remote firmware updates.
    ECC is coupled with the free MFP Mobile Diagnostic Tool (MMDT) 2.0 for rapid analysis of the 03/ 05/08 codes that ECC pulls down from each copier via the Cloud at scheduled intervals.
    As a Security feature ECC cannot contact a copier in the field other than at the exact time scheduled by the local ECC Administrator to upload/ download 03/05/08 data.
    You also need to enable 08-3820-1 to turn on ECC on each copier that you plan to bring under this service.
  3. #3
    Senior Tech 100+ Posts
    Join Date
    Dec 2010
    Location
    Albany, NY
    197
    Rep Power
    28
    I don’t know much about how the machines get into cloud connect, but to use it:
    the web address is: Log On
    Use the email address associated with your FYI account for username and use your FYI password for the password.
    I had to take an e-learning course before I could login and use it. Now that “They” have upgraded the systems to Global One, not sure how anything works now about granting access. I guess you can log a call ticket and wait for the nice folks in India to ignore you.
    Good luck.
  4. #4
    Senior Tech 250+ Posts
    Vincent128's Avatar
    Join Date
    Sep 2015
    326
    Rep Power
    26
    Use it and love it.
    You have to take the correct CBT's for cloud connect to be added as a user (I am our admin) - machine either are already added to your dealerships database or there is a link to have the machine added.
    Is used to backup the machines info, backup the machines addressbook, pull down the CSV's and poke into MMDT2 which a awesome.
    I have policies running to alerts us about low/no toner and special customers can 'pay' for the added feature of monitoring error codes
    You can set it up to load firmware's, over ride or alter 05 and 08 codes (I have a group policy for all our setup stuff like fax programs, service contact and phone number, double clicks..etc)
  5. #5
    Service Manager 5,000+ Posts tsbservice's Avatar
    Join Date
    May 2007
    7,103
    Rep Power
    346
    Quote Originally Posted by Vincent128 View Post
    Use it and love it.
    This sounds awesome especially overriding/altering Service codes, I will use it if available.
    I don't reply to private messages from end users.
  6. #6
    Join Date
    May 2015
    Location
    Derry, NH
    131
    Rep Power
    24
    Just a note to this: If you do have 3820 enabled and are working on the copier you should think about shutting it off temporarily because of the time it takes to run all it's internal processes when the copier has to reboot. You will end up doing a lot of waiting if you are changing 05 codes and the copier then has to reboot and then come back to ready.
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
