Results 1 to 10 of 10
  1. #1
    Senior Tech 100+ Posts
    Join Date
    Jan 2008
    125
    Rep Power
    0
    Cool Where do i have it? for pro.
    Hi all Pro. Tech !
    I look for codes after "line adjustment mode" maybe it is "2 level code", Pm me if any idea.
    Thanks and Best Regards.
  2. #2
    Join Date
    Jun 2016
    Location
    new york
    17
    Rep Power
    0
    Re: Where do i have it? for pro.
    wow !
    i am not pro. so not idea
  3. #3
    Service Manager 10,000+ Posts
    Phil B.'s Avatar
    Join Date
    Jul 2016
    Location
    Raleigh NC
    22,786
    Rep Power
    661
    Quote Originally Posted by MUMMIM View Post
    Hi all Pro. Tech !
    codes and procedure is in the manual
    what MODEL are you talking about?
  4. #4
    Join Date
    Jan 2008
    125
    Rep Power
    0
    Thumbs up Re: Where do i have it? for pro.
    Quote Originally Posted by Phil B. View Post
    In the manual isn't show it, the manual is only show before "Line adjustment mode" code.
    ex. 08-968 when 203 -1 at e230-232-350....
    Need for series have 4 number codes . from e 206 ...
    any idea else
    Thanhs.
  5. #5
    Phil B.'s Avatar
    Join Date
    Jul 2016
    Location
    Raleigh NC
    22,786
    Rep Power
    661
    any idea else
    Thanhs.
    look in ADJUSTMENTS
    i have never seen a Tosh manual that doesn't cover line adjustment
    did you clean the patch sensor?
  6. #6
    Master Of The Obvious 10,000+ Posts
    blackcat4866's Avatar
    Join Date
    Jul 2007
    Location
    Lapeer, Michigan
    22,469
    Rep Power
    463
    Line adjustment mode for eS206 is 08-9010.
    So what is this line adjustment mode used for? Neither manual explains what it is for.
  7. #7
    Senior Tech 100+ Posts Thayer's Avatar
    Join Date
    Dec 2017
    Location
    Burton, MI
    105
    Rep Power
    14
    "Line mode "
    Is usually used to turn off meter counter, but doesn't allow machine to calibrate.
    Allows tech to run prints and not add clicks on customer.
    Be careful and remember to turn it back off. Otherwise customer will be getting lots of free copies.
  8. #8
    Service Manager 5,000+ Posts tsbservice's Avatar
    Join Date
    May 2007
    7,143
    Rep Power
    346
    Quote Originally Posted by Thayer View Post
    "Line mode "
    Yep I believe so at least it was when I was doing Toshy.
    I don't reply to private messages from end users.
  9. #9
    Senior Tech 250+ Posts
    Vincent128's Avatar
    Join Date
    Sep 2015
    326
    Rep Power
    26
    0 - for factory shipment (meaning normal operation after leaving the factory)
    1 - for Line (meaning for use of the engine while it's still in the the Production Line - Most notably, it disables the total counter)
  10. #10
    Join Date
    Jan 2008
    125
    Rep Power
    0
    Cool Re: Where do i have it? for pro.
    Hi all !
    Understood ! it is very importance when we use line adjustment mode. So i don't write direct here about it.
    anybody haven't used it - don't put that code.
    This code is deep interpose the machine, open some code or mode that been hidden by Toshiba. It can clean and reset sensors, machine, correct some wrong which 08 code can't.
    i wrote : maybe it is "2 level code". any idea else?
    i am looking for it, if anybody have (machines number 4 code), pm me pls.
    Thanks all
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
