Thanks Thanks:  0
Dislikes Dislikes:  0
Results 1 to 4 of 4
  1. #1
    Trusted Tech 50+ Posts
    7845 gear noise like gear not engage ,after print heavy stock from by pass tray
    Join Date
    Aug 2014
    Location
    new york new york
    77
    Rep Power
    20
    print from bypass tray , 80lb cover 15 sheets ,out from center
    every time warm up ,now
    start up warm up gear noise very loud ,like gear not engage
    from transfer belt end screw or fused side ,don.t know
    any idea or comment are welcome
    Attached Images Attached Images
  2. #2
    Join Date
    Aug 2014
    Location
    new york new york
    77
    Rep Power
    20
    Re: 7845 gear noise like gear not engage ,after print heavy stock from by pass tray
    Quote Originally Posted by ps22sp View Post
    one more pics
  3. #3
    Senior Tech 100+ Posts
    Join Date
    May 2011
    168
    Rep Power
    31
    try the following :
    1. take out the bypass, check the gear on the left hand side for sign of crack.
    2. if you suspect fuser, try replacing it. or inspect the bearing of the pressure roller.
    3. record the noise / make a video of the noise
    any other sign like, toner status "please replace" eventhough you already replace the toner
  4. #4
    Join Date
    Aug 2014
    Location
    new york new york
    77
    Rep Power
    20
    Quote Originally Posted by shinchan View Post
    try the following :
    thank your advice , today i already print overnight , then this noise happen ,just an hour ago , i try to took out transfer belt ,and check out the clean blade ,the gear stuck ,that is the problem,
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Get the Android App
IDrive Remote Backup
Lunarpages Internet Solutions
Advertise on Copytechnet
Your Link Here
